quick breather mod question
Old Jan 29, 2009 | 10:46 AM
99SR5's Avatar
so i had the breather mod on my 3rd gen and i didnt have to do anything for the front breather but i was wondering if i have to raise the breather on the front or anything else like trans or transfer case?
Old Jan 29, 2009 | 12:31 PM
qdude79's Avatar
If you feel you're going to encounter a situation that requires a rear diff breather, the others would be logical as well.
Old Jan 29, 2009 | 12:47 PM
abecedarian's Avatar
+1
The front diff may not be quite as important since it only get's used occasionally whereas the rear diff is the primary way to move the vehicle, but if the breather mod's not done, the gear oil will require more frequent changes. So which is cheaper- gear oil changes everytime you take it underwater or getting the proper fittings and hoses?
Same applies to everything else- if it gets submerged, it'll get water in it, so the fluids need flushed and changed.
Old Jan 29, 2009 | 03:13 PM
Matt16's Avatar
How is the front diff on the 3rd gen vented? Same as the on earlier IFS?
Yes, you need to put a breather hose on the front as well, its as easy to do as the rear. The transmission is vented through the shifter I believe, as is the T-case (less sure on that one though). Judging by the pressure in the tank on a hot day, I don't think that is vented.
Old Jan 30, 2009 | 12:14 PM
99SR5's Avatar
ok cool! so i guess im gonna bring the front breather up around the intake and the rear around the filler neck. thanks for the help guys
Old Jan 30, 2009 | 12:54 PM
Matt16's Avatar
Why not vent it into the engine bay?
Old Jan 30, 2009 | 01:00 PM
SR5's Avatar
SR5
x2
be for warned you will run into clearance issues with the replacement screw and the oil pan...you will have to trim it up..about half to fit right.
also qdude79 your 4runner looks really sick and clean...the removed strips and blacked out grille, and rims seem to really add to do classic look of the 4runner.
jashoeuh
Nov 18, 2024 08:08 AM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
thefishguy77
Aug 9, 2015 04:15 PM
makemusic116
Aug 2, 2015 04:40 AM
icentropy
Jul 14, 2015 10:23 AM
