wheel studs!!!!
Old Feb 2, 2009 | 01:08 PM
fireman1559's Avatar
wheel studs!!!!
i had a problem the other day i was on my way to the tire shop to get my front alligend and i broke 4 wheel studs like the lug studs on one tire i got it pulled off the road and a tow truck called so my question is how do i replace the studs i got new ones but not to sure on how to install them and take the broke ones out
any help would be great
Old Feb 2, 2009 | 01:15 PM
corax's Avatar
you'll need to pull off the wheel hubs (bearings and all) and remove the rotor. after that, knock out the broken studs with a hammer. to put the new ones in, stick the stud through the hole, put a couple washers (with a few drops of oil on them) on the wheel side and tighten the lug nut to pull it through (best done with an impact gun)
Old Feb 2, 2009 | 01:19 PM
jason191918's Avatar
What he said.
Old Feb 2, 2009 | 01:34 PM
do you know where i can get a diagram i am more of a visual learner i have one for manual hubs but i have ADD
Old Feb 2, 2009 | 02:28 PM
mt_goat's Avatar
http://www.4x4wire.com/toyota/maintenance/front_end/
Old Feb 2, 2009 | 11:42 PM
Yotapowa's Avatar
How did you break 4 wheel studs??
Old Feb 3, 2009 | 12:10 AM
scuba's Avatar
Old Feb 3, 2009 | 12:54 PM
im not sure how i broke 4 wheel studs but they broke i replaced them today and brand new lugs it wasnt as hard as i thought just a very time consuming process i am going to say i more than likely didnt have them tight enough im going to blame this on me it could be something else but not sure
kgcwb44
Jan 29, 2023 10:02 AM
yoder519
Aug 17, 2015 07:12 AM
accuracy
Aug 6, 2015 12:32 PM
upongame619
Aug 1, 2015 12:12 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
