exhaust question.
Old Feb 2, 2009 | 08:38 PM
vinnie94's Avatar
exhaust question.
so the two bolts on the the muffler side of the cat are completely rusted and rounded. i was wondering if i could just take the saws all to em and replace?
Old Feb 2, 2009 | 08:41 PM
Elton's Avatar
sure why not
Old Feb 2, 2009 | 08:44 PM
AndYota's Avatar
I would
Old Feb 2, 2009 | 09:10 PM
vinnie94's Avatar
i was just worried cause it looks like a bolt goes through into the nut that is welded to the flange on the cat. guess ill jus hack it up. thanks for the help!
Old Feb 2, 2009 | 09:16 PM
4Crawler's Avatar
I replaced mine with stainless steel bolts, nuts and washers, liberally coated with anti-sieze compound. I think I just put a socket on the nut and twisted it off to snap the bolt when I first took mine apart.
Old Feb 2, 2009 | 09:22 PM
Jay351's Avatar
I had to heli coil the exhaust manifold/ypipe on my girls 4runner. When I removed the exhaust pipe I broke the bolts. Just went to the local parts store and founds bolts that where the same size.
Go for it!
Old Feb 2, 2009 | 09:26 PM
vinnie94's Avatar
already tried to get a socket on. even tried to pound it on with a hammer, still didnt work. hell even vise grips didnt work.. time for the saws all!
Old Feb 2, 2009 | 09:29 PM
myyota's Avatar
Just cut em off and replace them with new hardware.
Old Feb 2, 2009 | 09:34 PM
Jay351's Avatar
Torch... Heat works wonders...
Old Feb 3, 2009 | 01:01 AM
ovrrdrive's Avatar
I think I'd probably use a grinder and a cutoff wheel to get most of it, and then grind the rest off. A sawzall is going to be kind of impractical there due to the cramped working space.
Old Feb 3, 2009 | 03:58 AM
GSGALLANT's Avatar
x2... mini grinder would be easier.
That said, are you just replacing the hardware because it's rusted, or are you taking it apart anyways to replace a gasket or cat converter or muffler, etc...
If you're just replacing them because they're rusted, I wouldn't bother doing it until you have a reason to.
Old Feb 3, 2009 | 05:12 AM
saitotiktmdog's Avatar
I would use a cut of wheel on an electric or air grinder if you have one. Saws all I think will shake things around too much.
Old Feb 3, 2009 | 08:45 AM
jheyne's Avatar
actually the saws all isn't too bad i just had to cut one of those bolts off a couple of days ago but i was only doin it because i like the sound better with no muffler
Old Feb 3, 2009 | 10:15 AM
vinnie94's Avatar
gonna give the saws all a try. jus cause i havent worked since december 1st and i dont get much for unemployment. plus cut off wheels are pricey. an im replacin them cause id like to get a free flowing cat.
Old Feb 3, 2009 | 01:37 PM
iamsuperbleeder's Avatar
typical... just sawzall em out, and tap the rest of the bolt through the other side with a hammer; it's just a bolt going through, it's not welded
alexcarey
Oct 14, 2015 06:05 PM
voiddweller
Sep 28, 2015 11:21 PM
Yont283
Sep 20, 2015 10:56 PM
Yont283
Sep 12, 2015 10:03 AM
