Harbor Frieight Engine Mount Bolts
Hey I have the HF engine mount and just wondering what size bolts do I need to hook up my 22re motor to the mount. I think the size is 12 metric but cant get the tread right. All the bolts I have tried cant work cause the thread are to big. I just dont want to mess the threads up cause it is a reman block. Any suggestions?
Just stop now and save yourself the heartache. Go to a wrecking yard and get some engine mounts. Don't use Harbor Freight mounts. I have nothing against HF. I get most of my tools there. But motor mounts just scream bad day. And as for the bolt size, I believe there is a list of bolt sizes somewhere around here if you search for it.
Yes I still have the bolts that match the engine block to the tranny, but I am looking for bolts to put the block up on the engine stand to I can dress the engine before I put it back in. I know the size of the bolts, but I just cant figure out the thread size. All the bolts I can find have the threads too big.
I stock some bolts that will work, several lengths available depending on how thick the engine stand supports, I have them in 60, 80 and 110 mm lengths. I think the 80 is what most folks use, but best to check by measuring the thickness of the stand mounting bracket and the depth of the hole in the block.
jon.r
Jul 11, 2015 03:34 PM
skoti89
Jul 8, 2015 12:05 AM
