bent bumper. repairable/worth it?
Old Feb 2, 2009 | 09:23 AM
Brendan's Avatar
i was trying to be a hero and pull a stuck full size ford out and ended up bending my rear bumper pretty bad. the middle came out and the ends went in. the bumper has been powder-coated and the coating looks good still but i'm thinking that if the bumper has to be heated up to be repaired, then that will definitely wreck the power-coating in which case, it will all have to be sandblasted and re-coated. probably not worth it if this is the case. i'm in a fairly small town and don't know of any place that i could ask so i'm looking here for opinions.
i could probably get a pic if that helps.
Old Feb 2, 2009 | 09:25 AM
yoder519's Avatar
i would just take it off if it was me. then go scrap it. its probaly illegal tho. im not running one and its illegal in my state and ive never got a ticket. ive been pulled over to and he never said anything.... then you could buy you a marlin back bumper
Old Feb 2, 2009 | 09:34 AM
algranger's Avatar
yeah i have the marlin bumper you can definitely keep pullin out fords with that one
Old Feb 2, 2009 | 09:36 AM
Brendan's Avatar
in a perfect world with more money, yes i could. $400usd = $498cdn + shipping + powdercoating + 13% tax.
their website only shows tacoma bumpers anyways. do they make em for pre-tacos?
Old Feb 2, 2009 | 10:11 AM
Cyclopsblown34's Avatar
If it is not a tube bumper, you should be able to remove the bumper, put the center in a vise with a couple rags protecting the powder coat and crank the vise down. It should push the center back in and the outer edges will pull back into place when the center moves. You'll probably have to do some finessing where the bumper bolts to the frame though. Use the biggest vise you can get to so the pressure is spread out over a wider area. It might need some hammering(with vise pressure) to help push it back but only as a last resort. If you don't have a vise, Pull the bumper, jack up the front of the truck and with the ends of the bumper sitting on pieces of wood and the center of the bumper pointing up, use the weight of the truck and set one wheel on the high spot of the bumper, it might push the pull back close to flat.
Old Feb 2, 2009 | 10:19 AM
yoder519's Avatar
yea they make em for pickups:
\http://marlincrawler.com/armor/rear-...s-and-4runners
Old Feb 2, 2009 | 07:35 PM
xjdubber's Avatar
think about getting some reall tow points maybe.......
Old Feb 2, 2009 | 08:10 PM
Brendan's Avatar
thanks for the valuable input.
Old Feb 2, 2009 | 08:22 PM
slacker's Avatar
not sure what your counting as a small town .. but Vancouver is NOT .. with a pop. of about 1.5 million people I think that makes it a City / Metropolus
Old Feb 3, 2009 | 03:27 PM
Brendan's Avatar
kamloops is where i'm at. i put vancouver as my location because most people on this board would have no clue where in the world kamloops is.
Old Feb 3, 2009 | 03:46 PM
sexasomniac's Avatar
I do! Only from hockey though. I would try to fix it and if you can't, just scrap it and get a replacement or an aftermarket. I had trouble getting mine to line up just from taking it off and putting it back on. I think I might just ditch it all together and save for an aftermarket one.
justdifferentials
14
Jun 11, 2017 08:36 PM
86 87 4Runners
Nov 20, 2015 07:46 AM
mreagen
Oct 5, 2015 04:27 PM
vikinghug
Sep 23, 2015 12:32 PM
AkitaDog
Sep 3, 2015 09:01 PM
