Compression problems 22 RE
Old Jan 28, 2009 | 05:47 PM
Levij83's Avatar
I just blew a head gasket on my 94 pickup. The mechanic replaced the gasket and various parts (timing chain, water pump, etc.). Now that he has begun the timing process he noticed a valve sticking. After more running it just got worse. After checking compression he found that #1 cylinder is at 110 pounds, #2 is around 50 lbs, #3 is about 40 lbs, and #4 is 110 lbs. He believes that the water which was in the cylinders caused it to blow the rings out. A couple of the cylinders were full of water when he tore it apart. Now it wont even idle. He has to rev it up and if he lets off it just dies. Anybody have any ideas? I'm already figuring i might just have to buy a new engine, but i'd like to keep from having to do that...thanks ya'll
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
the1998sr5
27
Nov 17, 2015 09:30 AM
RatOmeter
Oct 22, 2015 03:17 PM
thefishguy77
Jul 30, 2015 10:59 AM
