missing plug off egr
Old Feb 1, 2009 | 11:15 AM
gary96360's Avatar
hey there i have this wire not connected to the egr. i have a pic where it is connected. is that thing important?
Old Feb 1, 2009 | 11:33 AM
Jay351's Avatar
Thats the EGR temp sensor. As far as I know not many trucks, aside from cali trucks got that part. Mine doesnt have it...
you might have gotten a replacment from another model truck... If its unhooked and your truck came with it, you should be getting EGR code #71 ...if not, dont worry about it...
Old Feb 1, 2009 | 11:44 AM
gary96360's Avatar
i blocked it off with a bolt but i see that i have the plug that is connected to the wiring harness but not the connector attached to the egr. i could be getting that code but im not even sure that my check engine light bulb works, have to check it out. you think it will cause worse gas mileage with that thing disconnected?
Old Feb 1, 2009 | 11:51 AM
Jay351's Avatar
If you dont have the connector in the EGR and you are not getting a code, there is no problem...
Turn the key to on, the CEL light should be on. If not, its out....
mileage shouldnt be affected, but like I said. Not many trucks up here had that sensor from the factory. Its not needed.
Old Feb 1, 2009 | 11:56 AM
gary96360's Avatar
thanks for the help. something else must be causing my bad gas mileage 12 mpg in town, driving like granny lol
Old Feb 1, 2009 | 12:08 PM
Jay351's Avatar
Check for vac leaks
check for air leaks in the intake (between AFM and the TB)
do a full tune up (ngk or denso stuff!)
I get around 15-16 mpg mixed driving in the winter. Summer I get up to 21mpg.....
Old Feb 1, 2009 | 01:03 PM
gary96360's Avatar
ill go and have a look at the vac lines, im about to do the isr mod today using the stock hose off the tb and using a 45 degree belled end pvc pipe. i just changed the plugs and air filter. driving almost 90 percent in city doesn't help either.
Old Feb 1, 2009 | 01:19 PM
jason191918's Avatar
Yup, that is for cali trucks only. If you remove the EGR that is where the resistor goes for the CEL.
icentropy
Sep 16, 2020 02:47 PM
montanatruck
Feb 26, 2017 07:07 AM
dumpster84
Apr 30, 2016 06:03 AM
montanatruck
Jul 25, 2015 03:45 AM
Snort
Jul 9, 2015 03:58 PM
