Sway Bar
Old Jan 28, 2009 | 08:21 AM
86yota2wd's Avatar
Sway Bar
I was wondering why my 1986 2wd pickup does not have a sway bar because there is tons of linkage kits but no actual sway bars that i could buy. Not that having a sway is bad other than it creates some gnarly body roll. But i do enjoy the added flex without it even thought it is 2wd. I am just wondering if there is a reason there isn't one and if anyone knows more about it.
Old Jan 28, 2009 | 08:39 AM
DeathCougar's Avatar
Sounds like the previous owner(s) have removed it. All the 2WD trucks came with sway bars.
Old Jan 28, 2009 | 08:58 AM
86yota2wd's Avatar
Im pretty sure the sway bar was not removed. Because it was my grandparents truck and they used it to haul small loads and my grandma used it as her transportation. Plus i can't find the spot where it would mount up to?
Old Jan 28, 2009 | 09:11 AM
894x4pickup's Avatar
2 12MM bolts to the frame behind the A arms, then links and connects to the lower A arm.
Old Feb 1, 2009 | 12:11 PM
86yota2wd's Avatar
thanks for the help i actually was able to find where the sway bar was i am just wondering why it was removed and where i could possibly find a replacement
Old Feb 1, 2009 | 06:54 PM
abecedarian's Avatar
why it was removed? who knows....
replacement would be cheapest at the junkyard.
but if it's not causing you issues I wouldn't worry about it.
Old Feb 1, 2009 | 11:37 PM
space-junk's Avatar
if you cant find one at a junkyard, hit up DC (the first guy to respond to your post)...
he works for NIX99 and can get you whatever you want for your truck...
ladybugRC
458
Aug 21, 2020 10:41 AM
A2theK
Oct 14, 2015 07:10 AM
Obmi
Oct 4, 2015 11:30 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
potatopants
Sep 15, 2015 06:26 AM
