High Idle when cold 22r
Old Jan 30, 2009 | 05:40 PM
Siris's Avatar
My truck idles high when it is cold then idles normal after it warms up.
The cold idle adjustment screw doesn't affect it.
I don't think the cold idle even works. the arm that is expose to come and meet it never moves doesn't move.
The choke works fine.
Could have anything to do with the air/fuel adjustment screw?
Old Jan 30, 2009 | 06:26 PM
Yodaforce's Avatar
How high?
Old Jan 30, 2009 | 07:18 PM
Tofer's Avatar
Sponsor
also wonders how high? my 22r idles at about 22-2500 when cold... let it warm up and it drops down to 900-1000
Old Jan 30, 2009 | 07:36 PM
rdlsz24's Avatar
It's normal
https://www.yotatech.com/forums/f116/cold-start-161237/
https://www.yotatech.com/forums/f2/c...-speed-160771/
Rob
Old Jan 30, 2009 | 07:38 PM
Yotapowa's Avatar
Its all good man. When you say your cold idle screw doesnt work, you may be turning the wrong screw, I did that for a while before i figured it out. Its on the back of the carb and when you open the throttle it gets turned up towards you(when standing on the passenger side)
Old Jan 30, 2009 | 09:57 PM
SteveyCapri's Avatar
same here
Old Jan 31, 2009 | 11:26 AM
Siris's Avatar
I don't have a tach but I would guess around 2000-2500 enough to where if I let up on the clutch I don't have to give it any gas
I'm sure that I'm messing with the right screw too.
This makes sense https://www.yotatech.com/forums/f116/cold-start-161237/
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
dumpster84
Apr 30, 2016 06:03 AM
calderp
Jul 27, 2015 09:58 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
ty1er
Jul 19, 2015 06:42 PM
