Power Steering Swap?
Old Jan 29, 2009 | 12:36 PM
red87's Avatar
I am looking to give my truck power steering real soon here (thanks tax return) but I don't know exactly what parts I need. I'm thinking I'll need the p/s pump, fluid reservoir, p/s steering box, and the belt/hoses. Did I miss anything? Also, does anyone know where I could get the whole swap?
Old Jan 29, 2009 | 12:43 PM
scuba's Avatar
no offense, but try searching... https://www.yotatech.com/forums/f116...utions-160657/ ....
Old Jan 29, 2009 | 12:45 PM
red87's Avatar
you know I actually did try that but failed at getting anything worthwhile. apparently your search kung fu is stronger than mine
Old Jan 29, 2009 | 12:58 PM
scuba's Avatar
lol, most people only look through the first page of searches then get angry, ish happens. Umm, Only thing you missed on your list is the cooler...Other then that, you should be good to go.
Old Jan 29, 2009 | 01:00 PM
red87's Avatar
ah gotcha, thanks for the help
Old Jan 29, 2009 | 01:11 PM
abecedarian's Avatar
pump, pump mount bracket, pump mount reinforcement bracket, hoses, cooler, steering box and draglink.
Scuba should be able to post a pic or two of the pump and brackets.
Old Jan 29, 2009 | 01:16 PM
red87's Avatar
would I be correct in assuming those parts are the same for all the 4 cyl pickups with IFS?
Old Jan 29, 2009 | 01:52 PM
DeathCougar's Avatar
Yes, all the 22RE setups are the same.
Scuba: Factory setups didn't have an oil "cooler" just a long looped line that fluid ran through. It wasn't much of a cooler, since it only had one 180` loop then went back into the system lol.
Old Jan 29, 2009 | 02:31 PM
would a 180 loop with fins be considered a cooler?
Old Jan 29, 2009 | 03:07 PM
scuba's Avatar
Hmm.......Abe I dont have any pics of the pump, But If the OP wants I can get one...
Old Jan 29, 2009 | 03:57 PM
How about shark fins?
With frickin lasers?
Old Jan 29, 2009 | 05:47 PM
scuba's Avatar
HOW DID YOU KNOW !!!!! Killer sharks with freakin laser beams on their freakin heads....!!
Old Jan 29, 2009 | 05:48 PM
I give you a pump and the brackets and you don't pic it?
Old Jan 29, 2009 | 05:57 PM
scuba's Avatar
I never installed it......./me hides...
Old Jan 29, 2009 | 06:02 PM
Fine... I want it back then.
Old Jan 29, 2009 | 06:17 PM
scuba's Avatar
Well yeah, since I wrecked my truck I was going to see if you wanted it back..
Old Jan 29, 2009 | 06:57 PM
I gave it to you. what you do with it is your concern.
Old Jan 29, 2009 | 07:53 PM
scuba's Avatar
Your to damn confusing man
Old Jan 29, 2009 | 09:48 PM
red87's Avatar
I'll take them Also, those pictures would be helpful for me. I can probably figure out what I need once I go to the junkyard but a little extra help would be appreciated.
Old Jan 29, 2009 | 09:53 PM
scuba's Avatar
http://personal.utulsa.edu/~nathan-b.../9descript.pdf && http://personal.utulsa.edu/~nathan-b.../steering.html for good measure...
