alternator ??
Old Jan 27, 2009 | 02:13 PM
highway's Avatar
alternator ?? (Solved)
Today out of the blue my brake light and battery light came on, is this usually the alternator ? Pulled it out this evening (man that was a task in itself) and gonna take it to a rebuild shop tomorrow.
Highway
Old Jan 27, 2009 | 02:23 PM
Matt16's Avatar
Highway
Chances are its the brushes- they are a wearable part and intended to be replaced at some point. You could go to your local autoparts store, buy the brushes for the V6 or 22RE alternator (they are identical) for $10 and install them yourself in 20 minutes. You need to know which end of the soldering iron is hot, but that's about as complicated as it gets.
Old Jan 27, 2009 | 02:24 PM
DeathCougar's Avatar
It could be a few things, but what those lights indicate is that the system is not recieving proper amperage from the alternator. This could be from a bad alternator, dead battery, or bad cables. 95% of the time, the alternator is toast or the belt is MIA.
Myself, i had this happen recently and the belt had broken (after only 6 months? WTF?!)
Old Jan 27, 2009 | 02:51 PM
Matt16's Avatar
I'd hardly call an alt with worn brushes to be "toast". Unless you've been driving around with mud suffocating the alt (heat buildup kills alts), its the brushes as I understand it. It was on mine.
Old Jan 27, 2009 | 02:55 PM
highway's Avatar
The alternator looks pretty clean and spins easy without any noise coming from the case.
Old Jan 27, 2009 | 03:05 PM
Toast=Not functioning. Take it however you will, but the fact remains that his alternator is not functioning.
Old Jan 27, 2009 | 03:06 PM
abecedarian's Avatar
Brushes do wear out and are fairly easily replaced. There is no guarantee that's your problem though, and you won't know until you tear it apart... so if you're up for spending the money and time to replace the brushes and it doesn't fix the problem are you ready to spend even more on top of that to replace the alternator?
Old Jan 27, 2009 | 07:55 PM
was thinking about saying:
Yep. Brushes being worn means nothing else is wrong... Guess you'd change the clutch plate / disc but not the pressure plate or check the flywheel too?
*not trying to be rude or harsh... just saying that one thing being worn does not mean there isn't another part worn as well.
Decided not to.
Old Jan 27, 2009 | 08:36 PM
15-love
Old Jan 28, 2009 | 07:58 AM
highway's Avatar
Well the brushes were wore out (196,000 miles) replaced those and charges normal now
highway
Old Jan 28, 2009 | 02:59 PM
Matt16's Avatar
So I guess it wasn't "toast".
Mine lasted about 180 000 miles before that were worn out, assuming they were orignial.
Old Jan 28, 2009 | 03:37 PM
The brushes were toast, so i'd say its operational properties were "toast"
Maybe you can use a piece of toast to cover your dash lights
Old Jan 28, 2009 | 04:18 PM
Bigblock's Avatar
LOL
Bigblock
Old Jan 29, 2009 | 01:21 PM
Junkers88's Avatar
Glad it was easy for you. Mine died at 171,000 and the replacement alternator died less than a 1000 miles later. Stupid front main seal went out and killed them both before I could find out where all that oil was coming from.
Old Jan 30, 2009 | 05:49 AM
highway's Avatar
wonder if anyone has fabbed up a splsh guard for the alternator ?
highway
Old Jan 30, 2009 | 05:50 AM
highway's Avatar
hehe
Old Feb 2, 2009 | 03:56 AM
TNRabbit's Avatar
highway
There are a few rubber alternator "gloves" around; I've seen them sell on ebay.
shooter86314
Jan 7, 2016 07:05 AM
Chicken12
Oct 14, 2015 03:54 PM
fountain
Sep 28, 2015 03:04 AM
SCZIG
Sep 20, 2015 09:00 AM
scheuvront1993
Sep 17, 2015 06:17 PM
