PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 [241] 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. New oil seal grease + packing
  2. Code 25- Please help diagnose
  3. Need advice on potential purchase - oil leak
  4. Urgent Brake Trouble
  5. What gives...Tire question for the pros
  6. Wheel wobble on one side of rear axle...Eh?
  7. 2nd gen ARB Bullbar + Budbuilt IFS Skid question
  8. rims
  9. Clutch Job
  10. 87 22Re Igniter/injector question
  11. 86 22re compression results
  12. 86 4runner Air Valve help/diagnosis
  13. temp/heater?
  14. LoadWarrior on a 1st Gen 4Runner
  15. wrong rear shocks?
  16. oil pressure guage no longer working.
  17. Help rear lift info needed for 91 run
  18. gurgle behind dash?
  19. shifting problems
  20. whining front end
  21. BRRRRRR!!! no heat!
  22. R.i.p.
  23. This may be a stupid ring and pinion question
  24. Anyone used rockprod's kit on a 22re rebuild?
  25. 63" Chevy Leaf Springs
  26. Rear locker or IFS lift?
  27. California 3.4 swap parts source needed
  28. Ok, is 17MPG bad?
  29. 3.0 V6 question
  30. Knock sensor
  31. Shifting Into Gear/s Issue (Not Shifter Seat)
  32. 3VZ-E photos?
  33. Best clutch cylinders for 22R
  34. Not sure whats going on here, 1990 4runner v6 3.0 letre manual
  35. my 3.4 swap + T-100 auto into 89 4x4
  36. Factory Service Manual: available on-line?
  37. clutch acted real weird now slipping?
  38. Cracked Head - Top end replacement?
  39. Look what I got for free (Don't laugh)
  40. Powerstering
  41. 3.0 timing belt marks ? WWWTP?
  42. starter issue?
  43. Door won't open lock stays locked....
  44. Identify this rear disc brake caliper.NEED REAL TIME HELP.
  45. anyone know where i can get a print out on the shifter assembly
  46. 92 4runner wont start in freezing weather help!!
  47. 22re injector question
  48. 22RE distributor Question
  49. Tranfer case or Axles?
  50. How Long Can You Drive a Toyota?
  51. -10F - Truck started, shook, died... suggestions?
  52. Help with 22RE after head gasket
  53. Converting 2WD to 4WD
  54. Dome Light
  55. bumper help
  56. spare removal
  57. Where to get a new Head Gasket-22RE
  58. Growling front wheels
  59. 16ft-lbs worth $100? => ARP vs EPN
  60. Super low idle speed
  61. 87 pickup regular cab Modified to x-tra cab using 90-94 rear windows.
  62. 22re cylinder heads pre vs post '84
  63. 92 4runner FSM
  64. FJ ROOFRACK ON 95? What ya think?
  65. Rear bumper guestion
  66. Stolen cat converter replacement ideas
  67. Rings and Bearings
  68. Just checked my fuel pressure
  69. Smitty bilt front and rear tube bumpers
  70. Rear Defogger Not Working. PLEASE HELP!
  71. pics of t-case cooler relocation??
  72. The Diff breather mod
  73. Fuel Injector Pintle Caps
  74. 2 2nd gen 3vzed used headers deals on craigslist
  75. 1rst run on the new legs
  76. LS1 swap help
  77. electrical problems
  78. Cool rear bumper
  79. Brush Guard
  80. Auto Tranny Service Parts
  81. Has anyone else had this happen...E Fan blade brakes at water crossing ?
  82. Lift Thread + Alignment Questions.
  83. Truck Hard To Start When Cold
  84. Another (different) whats it worth?? :)
  85. Engine Gods - help with head gasket
  86. Considering a 95
  87. Wierd water pump leak?
  88. Need help with CEL Codes
  89. D&H Fender Replacements
  90. 22re Idles VERY bad
  91. Yet another will 35s fit specs inside
  92. temperature gauge doen't work.
  93. 3vze hesitation issue
  94. Helpful hint #4 stop noise on steering stop
  95. Any one know of a dash cover that fits well with clinometer
  96. Problem with clutch/clutch pedal
  97. 88 Fender flares? Domesic bed or import?
  98. heads on wrong side...
  99. 1990 4runner lift/tyre question .... from Romania
  100. Fluctuating idle with AC on and brake pressed - DEFINITIVE FIX!!!!
  101. 4'' suspntion lift .... tires?
  102. How do I get the alternator out?
  103. 22R same as 22RE?
  104. cigerette lighter repair
  105. AFM help in my local area
  106. any way to test removed egr?
  107. My 93 Pickup with Pics
  108. stock 86
  109. timing chain
  110. Gas gauge
  111. Intermittent starting
  112. Front Caliper Brakes
  113. bj spacers, sliders, or shocks?
  114. V6 vs 4 cyl.
  115. spindle bushing question
  116. amp location in a stadard cab...
  117. Cold Temps and Fuel Pump problems?
  118. Rear Defroster Switch
  119. Coil Conversion?
  120. Replacing an engine?
  121. Oil pressure gauge how to?
  122. Fuel Filter?
  123. A340 H Tranny 1991
  124. 3.slow to 22re electrical ?
  125. Fj80/LX450 Rim question
  126. What exactly is involved when the "turn the crank"
  127. Squires turbo systems
  128. Auto transmission woes
  129. motor makin me mad
  130. Installing a Stock Yota Turbo to a 22RE
  131. 4.56 yukon gears
  132. 1.5 to 2inch lift for my 86 yota
  133. Picture of v6 radiator drain cock?
  134. TJ Coil Lift
  135. rough start and misconnected wire help plz
  136. Ball joint spacers?
  137. o2 sensor and exhaust questions
  138. Ridge reamers to remove piston lip?
  139. 97 2WD wheels onto 88 4WD?
  140. A raise in temperature when a/c turned on
  141. Fuel pump ?
  142. 3.0 V6 w/ Low Compression #3
  143. oem replacement springs, 94 2wd
  144. Rear U-joint replacement info needed
  145. 22re Break In
  146. Rear Springs: TG 3" or 4"
  147. Idle issue
  148. two more isr pipe mods
  149. 95 4runner v6 low cylinder pressure
  150. When to Replace Timing Cover?
  151. 93 fsm work for a 95 runner?
  152. What are these for?
  153. Engine wizards.....where do I stop with this??
  154. Backspacing
  155. oil pressure sending unit
  156. 90 Toyota 4Runner Engine Replacement
  157. frame repair
  158. 90 4runner axle bearing replaced..replace inner seal?
  159. starter solenoid
  160. 22R Fuse Layout
  161. Interesting Overheating Issue
  162. 22re Bore Size
  163. Driving with no hubs. Safe? Urgent!!
  164. 3.0 MAF making sucking sounds
  165. adjustable shocks worth it?
  166. Remote turbo for a 3vz?
  167. SAS-axle type
  168. Anyone turbo their 22r
  169. 1990 4Runner (2ndGen) Factory Service Manual
  170. Herculining Bumpers with rust spots??
  171. Got rust covers :D
  172. Got 35's or bigger? Pic please...
  173. Going up.. rear and rim ?'s
  174. finding rear main leak
  175. Fuel Pressure gauge.
  176. Axle Q? G144 = 4.88
  177. Cheap Headgasket OK?
  178. 1st Gen Bed on 2nd Gen Pickup?
  179. Pic request, 92 pickup
  180. stock roof rack
  181. gas cap location on flatbed
  182. Instaling a Tack in my 89 v6
  183. Forgot to apply sealent to flywheel bolts.
  184. Manual Shifter rattling noise
  185. Engine "surging" after warm up.
  186. 22RE engine stumbling....
  187. 89 4R 22re into 81 SFA P/U
  188. How is your front bumper is mounted
  189. gauge cluster plexiglass removal?
  190. Why does the middle camshaft support on the cylinder head gall out?
  191. Lower control arm cam bolt bushings-washer question
  192. front diff removal
  193. stumbling/hesitating when it reaches operating temp---egr valve?
  194. What years will fit 3.0
  195. 94 toy 22re Runs then dies.
  196. bell housing wont come off!
  197. Rear Axle Strength
  198. 95 4Runner antenna HELP!!!!
  199. Parts CD - anyone got one
  200. 3.4 swap interference
  201. Rear Third chipped
  202. Seat replacement options for 1987 4x4 ext cab
  203. Dreaded oil cooler leak
  204. 95 4Runner Hood Scoop (PICS)
  205. "Seat Delete" Panel?
  206. 95 4Runner Diving in deep water.. SNORKEL TEST (PICS}
  207. water pump weep hole?
  208. Any tricks for removing rear shackle bushings?
  209. Flipping Yer Tbars? Thoughts?
  210. 33-10.50-15 4Runner (PICS)
  211. Vinyl Carpet Replacement.
  212. Ironman Suspension on ebay
  213. shift rpm point
  214. Please help. Cant remove old shackles!
  215. cam shaft positioning after 3.0L hg job
  216. alternator not charging battery. help!
  217. How do you flush block?
  218. New OME901's Installed *Pics*
  219. 7.5" IFS spool?
  220. Brass washers reusable?
  221. oil pressure
  222. Off center Axle?
  223. Clock connector for 1988 pickup
  224. 901's installed...pics
  225. SAS with buggy spring shacle mount? and steering question.
  226. 4.88's and daily driving....
  227. Death of a project...
  228. Thnking about buying 84 4runner parts
  229. Interior question
  230. gear oil change
  231. Auto Trans Maintenance
  232. New plans, selling drivetrain
  233. Camping and Exploring rig
  234. 3VZE California model not running well
  235. cruise swap into an /86
  236. Air-Fuel meter on 3vz
  237. Cruse Control Location
  238. compression testing procedure?
  239. V8 Radiator, 4 Core BIG & Electric fans.
  240. Ignitor and knock sensor?
  241. 22-REC...check engine light codes and lack of power question
  242. 22re gas smell
  243. No Oil Pressure Light?
  244. Black or Stock Wheels!!
  245. 92 4x4 Pickup to 4 runner front end conversion.
  246. 3VZ Engine Block Question
  247. '94 battery/electrical failure
  248. 2nd gen diff question, v4 and v6 rear diff
  249. Can a head like this be cleaned up a bit?
  250. gear suggestions
