Yet another will 35s fit specs inside
Old Jan 12, 2007 | 08:25 PM
NC-B17A's Avatar
I have a 90 4runner with BJ spacers,OME T-bars & 2in lift springs in the back, also a WabFab 1in body lift & 33x12.50 BFG ATs on 15x8 wheels with 3.5 bs
I have a set of 15x10 wheels with 4in bs that i'm going to use
I really want a set of "35"x12.50s I have been looking at several different tires & have found almost an inch difference in "35s"
Diameter Section with
Dunlop Mud Rover 34.1 13.2
Maxxis Bighorns 34.7 12.5
Maxxis Buckshot 34.6 13.1
Kumho 834 Mud 34.5 10
Mastercraft MT 34.85 12.87
BFG MT 34.8 12.5
I can do .5in more of body lift & am ready to trim the fenders & remold my Bushwacker fender flares, flatten out the pinch weld , massage the fender wells with a hammer or even do alittle cutting.
Am I missing something in thinking that I can get 35s with below 4" of lift?
Old Jan 12, 2007 | 08:27 PM
em3e3's Avatar
What gear ratio are you running in your differentials?
Old Jan 12, 2007 | 08:38 PM
all_terrain17's Avatar
Cranked T-bars?
Oh and I noticed the same thing on the Kumho's - a 12.5 that's actually 10" wide?
Old Jan 12, 2007 | 09:05 PM
NC-B17A's Avatar
I have 4.88s with an LSD in the rear & it sits level so the T-bars are cranked to .5 for a total of 2 ins of lift in the front.
Old Jan 12, 2007 | 09:23 PM
If gonzo can do it with a a 2 inch BL and a bit of trimming I don't see why you can't ...
Old Jan 13, 2007 | 01:13 PM
NC-B17A's Avatar
I sent gonzo an IM thanks for that
Old Jan 16, 2007 | 08:29 PM
NC-B17A's Avatar
Well Tire Rack has the Kumho 35x12.50 specs at 34.5x12.1 @ 58lbs im gonna see if I can verify that
Old Jan 16, 2007 | 08:33 PM
Flygtenstein's Avatar
Forget magic tire size web site measurements.
The 10" wheel will be crappy for fit at that height.
Get in the 4" BS range.
At that height, if you wheel, you are going to rub. We are not talking about trimming, we are talking about cutting some crap OUT!
If your bars are cranked and the suspension doesn't really compress, you might be able to drive down the road.
Old Jan 16, 2007 | 08:37 PM
NC-B17A's Avatar
I have not prob cutting the fender well
Old Jan 16, 2007 | 08:38 PM
If the suspension moves, we are talking fire wall and holes.
Old Jan 16, 2007 | 08:54 PM
NC-B17A's Avatar
Yeah the firewall in the fender well I have no prob cutting & having it welded & I have even thought about cutting it & fiberglassing the cutout because I can do that my self
& yes my suspenion does move so that is a problem I will have to deal with if I go 35s
Old Mar 11, 2007 | 01:38 PM
deSCHUTTER's Avatar
that seems like a lot of work to cut man, probably easier just to lift it a little more, look better and you get more go before show!
Old Mar 11, 2007 | 06:49 PM
95RunnerSR5's Avatar
check this out...https://www.yotatech.com/forums/show...4&highlight=35
Old Mar 11, 2007 | 07:30 PM
Rcross's Avatar
On my 91 I have cranked T bars a 2in BL and I'm sitting on 35's. I didn't have to cut into the floorboards but I did do some persuasion with a BFH, I have no rub with full compression from wheel lock to wheel lock.
foampile
Dec 18, 2022 01:29 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
agrout
Aug 13, 2015 06:12 PM
TDonkey
Jul 26, 2015 10:14 AM
crashburnoveride
Jul 10, 2015 06:39 AM
