22re Bore Size
Old Jan 9, 2007 | 04:53 AM
RD1970's Avatar
22re Bore Size
how big can u safley bore a 22re block? mine is at .5mm now and it needs bored again.
Old Jan 9, 2007 | 05:54 AM
Th3duke's Avatar
When I re-did my 22RE it was bored to .30 over but I've been told you could go .40 over with these engines.
Old Jan 9, 2007 | 07:30 AM
dcg9381's Avatar
You can go up to 94mm, which I believe is .080. Note, not all engines will take this bore, so you have to be careful...
I'd say up to 93.5mm - .060 is fine... After that, you have to be careful.
Old Jan 9, 2007 | 08:13 AM
Yota82's Avatar
Stock bore is 92mm, if you are at .5mm (92.5mm), I would say to go 93mm but you can go 94mm. Sometimes odd sizes are hard to find depending on what you are looking for.
Old Jan 9, 2007 | 08:18 AM
dcg9381's Avatar
Generally, you can get .5mm sizes or .020 over... Beyond .040 over, you may have to look hard.
I'm at 93.5mm, absolutely no problems on a forced induction motor... Course, I don't have a lot of miles either.
My supercharged rig was 93mm .040 - no problems either.
LC does an overbored/stroked turbo motor at 94mm - .080 over - but I don't think all blocks make the grade.
Old Feb 8, 2010 | 05:16 PM
nickydmt's Avatar
LC's site says a maximum of 93mm?
RatOmeter
Oct 22, 2015 03:17 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
upongame619
Aug 1, 2015 12:12 AM
PopsDad1
Jul 30, 2015 02:21 PM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
