Ball joint spacers?
Old Jan 10, 2007 | 04:37 PM
8yota9's Avatar
Ball joint spacers?
What are ball joint spacers what do they do? more lift better traction? are they worth it? please some kind fello fill me in
Old Jan 10, 2007 | 04:41 PM
881stGenRunner's Avatar
https://www.yotatech.com/forums/show...ljoint+spacers
Not trying to bust your balls or anything, but that is one the most talked about items here on YT. A simple search for ball joint spacers will yield thousands of answers! Good Luck.
Old Jan 10, 2007 | 08:40 PM
4Crawler's Avatar
See:
- http://www.4crawler.com/4x4/ForSale/...ntSpacer.shtml
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Old Jan 11, 2007 | 07:34 AM
norcalsvx's Avatar
they are great i love mine
Old Jan 11, 2007 | 03:38 PM
8yota9's Avatar
Haha its cool thanks alot sites are verry helpful
Old Jan 11, 2007 | 05:14 PM
8yota9's Avatar
will thease suckers fit my 89 4wd v6 3.0
and they go on the top controle arms using all other stock parts that came off like bolt up and go type thing and if eneyone who has thease could post pics that would be verry nice thanks a bunch
Andrew
Old Jan 11, 2007 | 05:16 PM
all_terrain17's Avatar
Yep. They'll fit. Check RB's site for details...
Old Jan 11, 2007 | 09:08 PM
AxleIke's Avatar
I have a bit of a question for alls who's been running these things.
I have beaten mine up pretty good, and in my recent (an unpleasent) front joint replacement, i found that i had bent one of the BJ spacer mounting studs so badly that it is going to need to be cut out.
They are an M8, 125 thread pitch, i believe. My question is, anyone have any luck finding that bolt in the length needed here? Other than ordering it online? Like to get it soon.
I have both spacers out of the truck at the moment, which is kinda funny to see, but need to get them back in sooner rather than later, thanks.
Old Jan 11, 2007 | 09:18 PM
4Crawler's Avatar
I can ship you a replacement or two, $2.00 via First Class mail, $6.00 via Priority Mail (2-3 days) or $16.00 via Express Mail (1-2 days)
Old Jan 11, 2007 | 09:37 PM
bob200587's Avatar
Here's my thread in which I came up with my decision not to run them.
https://www.yotatech.com/forums/show...er+experiences
I think what it boiled down to for me, was that I'm not gonna run tires big enough to really need them without SAS. And I don't need a SA because I don't like rocks....they're not very forgiving.
I'm going for more of a...camping/expedition/bug out/emergency/survival/whatever, deal
Just make sure you think everything through before buying.
Old Jan 12, 2007 | 09:45 AM
Sonofmayhem's Avatar
THey dont exist
Old Jan 12, 2007 | 05:10 PM
8yota9's Avatar
Are they werth it? ok, i have an 89 toyota p/u v6 3.0 witch u allready no if u read the thred eneyway i got a 4" trailmaster lift with 33 12.50 on there i want more lift can i get it a cheper way other than blocks cuz i got like 4" blocks in the back allready i want like an all round front to back 2-3" inches of lift bj spacers or it there a cheper /better way and what is a good gear ratio for a mild mudder thats a dalie driver?
Old Jan 12, 2007 | 05:54 PM
4Crawler's Avatar
Sure, ball joint spacers can be added to a 4" IFS lift kit. All the "mild" lift options on the page below would apply as far as adding more height to an existing lift kit:
Old Jan 13, 2007 | 12:45 AM
bob200587's Avatar
You can reduce all those problems by getting a skinnier tire. I also would reccomend you ditch the rear blocks in favor of some shackles or an add a leaf. Or even a leaf pack if you can afford it.
If I were going to run 33x12.50s on an IFS truck. I would just get a bracket lift. I don't think BJ spacers will give you the amount you need. they may, with some trimming or banging. I wouldn't run that wide of a tire though....It's just not worth it to me. The extra width doesn't help much off road, and it just causes problems when it comes to getting the right amount of lift, etc. Because if you're using IFS then you're probably not going to see alot of rocks, otherwise you'd already have done a SAS. And if you're not doing alot of rocks, or sand (which is a different story) I'd suggest a 33x10.50. The extra 2 inches in width will probably not be as helpful in mud as it is stressful to fit. I don't think it's possible to justify the use of a 12.50 wide tire on IFS...there's just alot more effective options for each situation.
Rocks: you might as well SAS and run 35's or bigger
Sand: You could stay stock if you're not jumping, or go Long travel to fit 33x12.50 or larger. The width would be more helpful here.
Mud: I don't think 12.50 wide tires have much if any noticable advantage to 10.50 wide tires in this situation. I've seen both in action and both have performed close to equally.
Save the money and run a skinny tire. They look better anyway.
Old Jan 13, 2007 | 12:50 AM
bob200587's Avatar
Also, the most used gear ratio for 33's is either 4.88 or 4.56. Since you have a 3.0 I'd say 4.88 with either auto or manual tranny. But I haven't driven a 3.0 so 5.29 might be a better ratio. better wait and see what the others say.
Old Jan 13, 2007 | 08:21 AM
slosurfer's Avatar
I would add the bj spacers but use them for more travel not lift, then add a body lift and then something to get rid of the blocks in the rear. I think the bj spacers are worth it just for the extra travel alone, where else can you get an extra 1.5" of travel for about 100 bucks.
Old Jan 13, 2007 | 08:36 AM
slosurfer's Avatar
Originally Posted by bob200587
If I were going to run 33x12.50s on an IFS truck. I would just get a bracket lift. I don't think BJ spacers will give you the amount you need. they may, with some trimming or banging. I wouldn't run that wide of a tire though....It's just not worth it to me. The extra width doesn't help much off road, and it just causes problems when it comes to getting the right amount of lift, etc. Because if you're using IFS then you're probably not going to see alot of rocks, .
There are plenty of folks running rocks in an IFS truck w/ bj spacers. MY rig is being built up as an expo/all around rig and I take it everywhere (rocks, sand, highway, etc...). I actually like the lateral stability that the 12.5's provide, especially with an already top heavy vehicle. With the correct backspaced rims and 12.5's my track is now 4in. wider than stock w/ 10.5's. Makes a huge difference offroad and onroad. I still like the 10.5's though but have noticed a difference. Plus it just looks badass! Oh yeah, the only trimming or banging I have done was to the valance.
Eventually I do want to SAS but I am amazed at what I can do in the rocks now. I want to run the dusy w/ IFS before I SAS, but we will see about that.
Old Jan 13, 2007 | 10:16 AM
Bear80's Avatar
The '93-95 3vze with the 340h tranny factory equiped with 31" tires will already have 4.88 gears. You will need 5.29 at least when moving to 33" tires. The 3vze with 5spd equiped with 31" tires came with 4.56 gears. I had this setup and ran a true 32" tire which was close to a radial 33" no problems. 86-92 22re or 3vze with the auto came with 4.30 gears and the 5spd came with 4.10.
BJ spacers are cheap and can give you the added down travel. To have it give improved upward travel, unload the torsion bars to set it back level and you gain more uptravel.
Old Jan 13, 2007 | 09:14 PM
AxleIke's Avatar
My IFS drives on the rocks....
Old Jan 13, 2007 | 11:36 PM
ya..........me too
