22re cylinder heads pre vs post '84
Old Jan 14, 2007 | 04:44 PM
rustypigeon's Avatar
Hello all. I was just wondering if anyone here knows if a pre '84 cylinder head will match up with a '94 trucks exaust and intake manifolds. I know the heads are different but I don't know if the bolts line up. I have an opportunity to pick up an '81 22r engine and I am not sure if I can swap it with my '94 22re with just a manifold change. Thanks.
Old Jan 17, 2007 | 07:27 AM
maxpower_hd's Avatar
The short answer is no. The heads on pre 1985 22REs are different than 85 and up. They have different deck heights, and different quench areas because the 84 and under ones had domed pistons. The exhaust ports are different as well. It may actually bolt on but it won't work.
The block also has a different deck height. The crank and rods are the same however.
Hope that helps.
bigjstang
Jun 2, 2025 03:56 PM
Colington
Mar 8, 2020 09:51 AM
nick9455649
Sep 11, 2015 05:10 PM
smiley52
Jul 11, 2015 05:16 AM
Cplmike
Jul 8, 2015 08:47 PM
