89 4R 22re into 81 SFA P/U
Old Jan 8, 2007 | 12:31 AM
SwampThing's Avatar
Question 89 4R 22re into 81 SFA P/U
How "Bolt-Up-Able" would that be? Thinking about buying this 81 sfa p/u w/o an engine, tranny, and xfer case, and swappin all I need outta my 89 22re equipped 4Runner into that. Bout how much fabbing and aftermarket kits and parts would be required? Pretty straight forward swap, or...? Thoughts and opinions appriciated!
Old Jan 8, 2007 | 03:05 AM
milowilli's Avatar
Will you be using EFI or carb?
Old Jan 8, 2007 | 05:29 AM
maxpower_hd's Avatar
I believe it will bolt right in. I may be wrong but I think it will work. You would need you computer and wiring harness too.
Old Jan 8, 2007 | 10:42 AM
SwampThing's Avatar
My 22re is fuel injected. So engine, tranny, computer, and wireing harness.
And I'm also not sure what the 81 is geared at, but I have 4.88s in my 89. Would those gear sets fit into the 81 or would I have to buy new ones? no biggy if I do, I always wanted 5.29s
Old Jan 8, 2007 | 04:13 PM
SwampThing's Avatar
Badda bump
Old Jan 8, 2007 | 04:35 PM
Sonofmayhem's Avatar
its easy if you swap over your dash and comp as well. i had an 89 truck harness and an 89 4runner harness and they were way different. to make it easier swap everything unless you get a wiring diagram and are comfortable with making it work.
MMA_Alex
25
Apr 18, 2017 05:07 AM
1994Toyota4X2
Aug 22, 2015 06:27 AM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
