oil pressure sending unit
Old Jan 9, 2007 | 01:06 PM
spudrunner's Avatar
Do I need to use any type of thread sealer when installing?
Old Jan 9, 2007 | 01:09 PM
DudeBud's Avatar
cheap insurance. thread tape works..
Old Jan 9, 2007 | 02:10 PM
spudrunner's Avatar
Thanks, well I've been out there almost an hour trying to get the old sending unit off and it won't budge. Had an 18" long breaker bar on there and still no luck. Also used PB blaster. It's an 88 4 runner and I'm sure that's the original sending unit. What the heck is that thing torqued down to from the factoty? I'm pretty bummed out cause I wanted to install my new (used) sr 5 gauge cluster. Anybody got any ideas how to get that dam thing off?
Old Jan 9, 2007 | 05:57 PM
InternetRoadkill's Avatar
Don't thread seal it unless it has a ground wire or least don't use tape. The tape can interfere with the electrical contact the sender needs to make with the block.
Old Jan 9, 2007 | 08:13 PM
DudeBud's Avatar
the threads are somewhat tapered so they will cut the tape enough to ground the sending unit out
Old Jan 10, 2007 | 09:02 PM
sdstud212001's Avatar
I had to use Vice Grips and go through the wheel well to access it better to get mine off.
Old Jan 11, 2007 | 04:20 AM
mt_goat's Avatar
Yeah I used teflon tape on mine and it works fine, so it must have cut though enough to ground.
The factory torque spec isn't very much, I'm sure the years of corrosion have frozen it up. Be carefull, you don't want to snap it off. IIRC they are brass threads.
Doug4320
Mar 24, 2018 10:11 PM
skoti89
Sep 11, 2015 07:46 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
