stock 86
Old Jan 11, 2007 | 07:44 PM
madbronco's Avatar
stock 86
I was wandering if a set of 33x12.5x15's would fit on a stock truck? tape says they will, just wandering if anyone has done it?
Old Jan 13, 2007 | 02:02 PM
madbronco's Avatar
come on someone has had to done this..
Old Jan 13, 2007 | 02:39 PM
Sonofmayhem's Avatar
yeah lets search its been done, youll get a ÅÅÅÅ load of rubbing unless you get a body lift w/ or w/o bj spacers or a 4in suspension lift.
Old Jan 13, 2007 | 02:47 PM
Bear80's Avatar
Originally Posted by Sonofmayhem
yeah lets search its been done, youll get a ?…?…?…?… load of rubbing unless you get a body lift w/ or w/o bj spacers or a 4in suspension lift.
wrong. If you load the t-bars to gain about 1" you'll be fine with a little pinch weld rub. you can hammer it down if you want or leave it. The most rub will come from the mud flaps. This is assuming you have the stock 7" wheels. I have a set of 80 series lc wheels that are 8" on a 4runner with 1" t-bar lift and they rub a little more than the stock 15" wheels did.
Old Jan 13, 2007 | 02:57 PM
i thought it said 35 woops, still you newb search
Old Jan 13, 2007 | 04:40 PM
all_terrain17's Avatar
You'll probably rub on the bed though if you don't trim or lift the rear though, right?
Old Jan 13, 2007 | 04:43 PM
CJM's Avatar
CJM
In short, you need a lift to fit, it will rub the fender weld or the rear/bed
justdifferentials
14
Jun 11, 2017 08:36 PM
4.34runner88
Feb 7, 2016 02:24 AM
noahstancik
Sep 10, 2015 10:47 AM
josh21
Sep 9, 2015 03:26 PM
AkitaDog
Sep 3, 2015 09:01 PM
