What exactly is involved when the "turn the crank"
Old Jan 11, 2007 | 05:58 AM
vmax84's Avatar
What machine work is actually performed? Does that mean all they do is balance it? Thanks.
vmax84
Title should read "when they turn the crank".
Thanks.
Old Jan 11, 2007 | 06:16 AM
19RUNNER86's Avatar
they machine the crank to make it smooth and even and balance it.
Old Jan 11, 2007 | 08:11 AM
maxpower_hd's Avatar
Actually, when they "turn" the crank it is to remove metal to accomodate undersized bearings in the event the crank is worn beyond it's factory specs and cannot use original size bearings.
They "polish" the crank to make it smooth, if needed.
They check and balance the counter weights, if necessary, after removing material from the crank.
It really depends on why it was removed and how much damage is done if any. If they are just checking the crank compared to factory specs, they may actually not remove any material at all.
Old Jan 11, 2007 | 08:18 AM
vmax84's Avatar
Thanks for the responses. Also, what would be a typical price for having the engine block cleaned, bored (22re engine), and crankshaft turned? I was quoted 59 to clean, 18/cylinder,and 100 to turn the crank from a good machine shop. Just comparing prices. Thanks.
vmax84
Old Jan 11, 2007 | 08:32 AM
dcg9381's Avatar
Cleaning (hot tank) - I dunno...
Those prices are fair... $100 to turn the crank is a good price.
I'd recommend having your machine shop measure the pistons before you bore it.. As the pistons can vary, the bore size may vary a little bit also.
Rings have to be sized to the bores also.
Typical machine work costs for a rebuild (including the head) run between $400-$600 in my area.. For a high end job, including full balance, $600-$800.
jasonty
41
Dec 23, 2018 01:00 PM
okamikai
Apr 30, 2018 10:19 PM
jordyy
Aug 4, 2015 12:12 AM
Nailit69
Diesel Swaps
Jul 21, 2015 05:28 PM
Hamonacracker
Jul 17, 2015 08:33 AM
