3vze hesitation issue
Old Jan 12, 2007 | 06:34 PM
chimmike's Avatar
Welp, here's my best explanation:
I'm getting this weird hesitation. It's gotten worse as of late, on acceleration. Occasionally I'll hear like a 'clunk' type sound, just a single clunk w/ hesitation, and then it'll contine on (while accelerating). I'm going to check all the plug wires again tomorrow, but I'm getting worried that it might be something more serious. I can't feel any weird vibrations, and there are otherwise no abnormal sounds......but of course the motor is incredibly sluggish!
Thanks guys
Old Jan 12, 2007 | 06:51 PM
TOYZILLA's Avatar
3.0 VZE Hesitation
I'm going say the thump your hearing is a backfire from within the intake.You could need a tune up & pos look for vacume leaks,also look to see if your air filter could be clogged. hope this helps.i'm sure there is someone else that may have had same prob & can direct you in the right direction.
Old Jan 12, 2007 | 07:24 PM
thook's Avatar
Yeah, sounds like it's running rich. Have you noticed any change in your mileage, too? Any crud at the tailpipe? How does it idle?
Old Jan 13, 2007 | 05:11 AM
chimmike's Avatar
idle is much better since i've changed the plug wires, kinda steady at 700rpm. The air filter is a brand new K&N. So i'm thinking it's essentially the spark plugs and I need to go along and replace the rest and make sure the wire boots are fully on the plugs for full force.
I might try an MSD coil or something along those lines for a little more fire if the spark is weak....or increasing the base timing a degree or two.
Old Jan 13, 2007 | 07:22 AM
thook's Avatar
Okay, good luck. Post up if it doesn't do the trick.
Old Jan 13, 2007 | 08:52 AM
chimmike's Avatar
I can't get my fat hands around 2 of the plug boots to push 'em on fully
DeathCougar
Apr 1, 2018 11:29 PM
HollieJayyy
Aug 9, 2015 07:59 AM
clok
Aug 1, 2015 09:42 PM
91yotapup
Jul 27, 2015 07:19 AM
smiley52
Jul 11, 2015 05:16 AM
