3vze torque problem
Old Jul 23, 2015 | 05:52 PM
91yotapup's Avatar
3vze torque problem
I have a 91 toyota pickup 3vze v6 and i have no power until about 3000 rpms. When I'm in 1st or 2nd gear it's a slow acceleration until 3000 rpms and then my torque jumps up a lot. Once I get into 3rd or above I have absolutely no power. Any tips or fixes?
Old Jul 23, 2015 | 08:30 PM
RJR's Avatar
RJR
That's pretty much how the 3vze runs. Below 3000 is for level cruising or coasting only. When you want to accelerate or go up a hill you have to get the rpm's up. I seldom upshift below 4000 rpm until I've reached my final speed.
Old Jul 24, 2015 | 01:51 AM
91yotapup's Avatar
Thanks I was just being sure I didn't have a throttle body problem or so forth. And I'm hoping to toy around with some things to get some more bottom end from it
Old Jul 24, 2015 | 05:59 AM
fdp101452's Avatar
Whats it timed at... Ive found bumping the timing to 12 or 15 helps a lot. Some run more advance than that.
Old Jul 24, 2015 | 06:02 AM
91yotapup's Avatar
I'm not sure what my timing is set at because the guy I bought it from did modify some parts of it. But I'm 99% sure it's factory offset
Old Jul 24, 2015 | 06:49 AM
scope103's Avatar
Originally Posted by 91yotapup
I'm not sure what my timing is set at ... But I'm 99% sure it's factory offset
Sure? How?
A timing light is $20 http://www.harborfreight.com/xenon-t...ight-3343.html It's one of the first tools you (should) buy. And your symptoms sound like a timing problem.
(Read the manual for how to check; you need a jumper to set it to base timing)
Old Jul 24, 2015 | 06:53 AM
91yotapup's Avatar
I'll probably go pick one up after work and then I'll get back with yall on all of the timing info
Old Jul 26, 2015 | 06:00 PM
91yotapup's Avatar
Thanks for the input y'all. I advanced the timing to around 12° and it cured my problem for the most part
Old Jul 27, 2015 | 06:44 AM
Janos01's Avatar
The issue might also be with your transmission from what you are describing.
Are you gears shifting normally or are they slipping?
Does your gas peddle operate fine or does it stop at a certain point where you do not have alot of speed? If this case, it might be your detint cable that runs to the throttle body to the transmission.
Old Jul 27, 2015 | 07:19 AM
91yotapup's Avatar
Everything else is working fine. I just didn't feel right having a v6 with no power and I was trying to up my low-end
colasurdo
Jul 18, 2015 07:06 AM
colasurdo
Jul 17, 2015 08:28 AM
colasurdo
Jul 16, 2015 11:32 AM
Snort
Jul 9, 2015 03:58 PM
Jnkml
Jul 6, 2015 01:20 PM
