Clutch Job
Old Jan 16, 2007 | 08:10 PM
david28's Avatar
Clutch Job
Im doing my first clutch job by following in my shop manual. In the book it says to remove the Clutch Slave cylinder by just unbolting it and leaving the line connected, what i cant firgure out is how to seperate the cylinder from my transmission theres a plunger or something still holding it to my tranny...
any help would be appreciated....
thanks
Old Jan 16, 2007 | 08:23 PM
Bill's Avatar
The plunger is part of the slave cyl, and isn't actually attached to the clutch fork. The fork has a small divot/dent/recess that slave cyl shaft just sits in.
Unbolt the two bolts on the bell housing, and the slave will(should) just swing away. You may have to "pop" the plunger out of the fork if it's stuck in.
Old Jan 16, 2007 | 08:33 PM
Spinnbait's Avatar
take time
Take your time with it. Be very careful to "press" the new pilot bearing into the crankshaft all the way. Also, be careful when centering the clutch as it seems simple, but does need to be accurate. Don't skip on the torque wrinch. Take care of the hydraulic lines. My clutch install was one of the most rewarding things that I have done, thought I did an auto to manual swap at the same time.
Old Jan 18, 2007 | 10:35 AM
david28's Avatar
thanks alot...mine was stuck in there pretty good
Old Mar 5, 2007 | 04:30 PM
8yota9's Avatar
what else can you replace as far as bushings,seals,gaskets,ect while the tranny is out?Also are the sincroes a real hard thing to do in a tranny?
thanks
Old Mar 5, 2007 | 09:27 PM
CyMoN's Avatar
I did mine this weekend best thing I have done so far, my truck feels new again.
at the same time I replaced the rear main seal oil pan gasket and fuel filter.
also either replace or get your flywheel resurfaced best 35$ bucks spent.
Old Mar 6, 2007 | 11:12 AM
8yota9's Avatar
what about in the tranny shifter seat bushing or somthing for a slopy shifter
Old Mar 6, 2007 | 12:43 PM
CyMoN's Avatar
did those also it feels a lot better now.
Old Mar 6, 2007 | 12:46 PM
surf4runner's Avatar
thanks
access to the synchros requires the tranny to be openned up. not hard to do, but not something for a novice to attempt alone.
Old Mar 6, 2007 | 01:19 PM
dcg9381's Avatar
Consider taking it to a tranny shop now that it's out. Just the fact that they don't have to pull it or reinstall it will save you some serious bank.
There's a shop in austin that does a flat fee rebuild for $250 + parts.
Old Mar 6, 2007 | 01:22 PM
GV27's Avatar
Definitely do that. You can get a heavy-duty one from Marlin Crawler.
Putting in new syncros is basically a tranny rebuild.
Old Mar 6, 2007 | 01:30 PM
8yota9's Avatar
can eneyone give me a part # for the shifter bushing or a real name and is that the same as the seat?
Old Mar 6, 2007 | 01:43 PM
CyMoN's Avatar
talk to Wabbit I got them from him
Old Mar 6, 2007 | 01:45 PM
GV27's Avatar
Same as the seat....
http://www.marlincrawler.com/htm/tra...rans_parts.htm
Old Mar 6, 2007 | 01:56 PM
8yota9's Avatar
thanks alot guys im getting the heavy duty clutch from marlin i hear it is a tuff clutch must be better than stock
Zach_trun
Nov 17, 2015 07:56 AM
noahstancik
Sep 10, 2015 10:47 AM
Regency
Sep 6, 2015 05:47 PM
Squigglez
Sep 4, 2015 07:33 AM
Nick Berg
Sep 3, 2015 04:36 AM
