water pump weep hole?
Old Jan 7, 2007 | 11:22 AM
PabloA's Avatar
on an 94 pickup 22r-e anyone know if the water pump has a weep hole and where its located?
Thinking I might need a pump. Getting a lot of dark built up dirt below water pump.
Old Jan 7, 2007 | 12:29 PM
drew303's Avatar
weep hole?
Theres only one hole on that water pump and thats where the shaft comes out that mounts to the fan.
It's not uncommon for the seal around the pump to go to but usually the shaft seal wears out.
Water pumps are only $25-$30 or so at a parst store.... then cost of fluids. Easy fix imo (done a few)
Old Jan 7, 2007 | 01:49 PM
mr toytech's Avatar
all toyota pumps have a weep hole. they usually right under the pully shaft bearing. and they will start to leak from there if the front seal is going bad.
Old Jan 7, 2007 | 07:42 PM
PabloA's Avatar
can this weep hole be visually seen from outside the pump?
looking from underneath the truck?
Whats a good pump to get? aftermarket or dealor?
hey drew303, clean truck man!
thefishguy77
Jul 30, 2015 10:59 AM
Logz808
Jul 26, 2015 07:09 AM
jjrbus
Jul 19, 2015 02:06 PM
Snort
Jul 19, 2015 07:03 AM
Jonny246
Jul 12, 2015 04:51 AM
