22R same as 22RE?
Old Jan 12, 2007 | 09:43 AM
Howdy's Avatar
22R same as 22RE?
I am looking at picking up an 87 4runner that needs an engine. I have a line on a rebuilt 22R. Is the only difference between the 22R and RE the injection system where one is carb and the other injected?
Thanks
Old Jan 12, 2007 | 09:47 AM
rdlsz24's Avatar
https://www.yotatech.com/forums/f115/difficulty-installing-22re-103728/
Rob
Old Jan 12, 2007 | 09:52 AM
Sonofmayhem's Avatar
RE=fuel injected
REC=fuel injected, california emmissions
R= carbed unless fuel injection was swapped onto the block but you should hopefully be able to tell.
Old Jan 12, 2007 | 10:21 AM
Howdy's Avatar
Thanks....It sounds like it should be a pretty easy swap to put the efi stuff from a donor truck on a carbed engine.
Old Jan 12, 2007 | 10:24 AM
maxpower_hd's Avatar
Short answer: You should be OK as long as the donor motor is 85 or up. 84 or earlier is different.
Old Jan 12, 2007 | 10:45 AM
Howdy's Avatar
Gotcha...are the accessory holes different? Does anyone know of an FAQ that explains the difference between the different model years?
Maybe I just better stick to an engine that is around the year of the Runner.
Old Jan 12, 2007 | 11:07 AM
dcg9381's Avatar
http://www.toysport.com/Technical%20...tech_notes.htm
Old Jan 12, 2007 | 12:02 PM
Howdy's Avatar
Great info! Thanks a bunch
Old Jan 12, 2007 | 12:12 PM
bob200587's Avatar
I'd stick with a carb. easier to work on, and impervious to EMP's
Old Jan 12, 2007 | 12:46 PM
dcg9381's Avatar
Until you try to climb a real hill...
Old Jan 13, 2007 | 08:18 AM
Howdy's Avatar
And if you live in CA you won't pass smog if you run the carb because the 4runner I am putting it into came with EFI.
Old Jan 13, 2007 | 08:39 AM
toyota_mdt_tech's Avatar
Thanks
85 to 95 22RE's were all the same ie heads etc. And EFI system will bolt right up. Not certain before 85, but suspect the intakes will interchange.
sandyota
Feb 4, 2021 11:16 AM
cars-guy
Aug 16, 2020 06:59 AM
dumpster84
Apr 30, 2016 06:03 AM
cars-guy
Jul 11, 2015 07:51 PM
87blyota
Jul 10, 2015 04:31 AM
