Where to get a new Head Gasket-22RE
Old Jan 14, 2007 | 10:00 PM
yotaknows's Avatar
My 22RE blew white smoke, lost coolant, did not overheat, and has a trace of water in the oil..so where is the best place and price to get my head gasket kit? Do I need new head bolts? It was running great when I shut it off, do I need to worry about the lower end having problems because of the HG? Any info is appreciated...thanks.
Old Jan 14, 2007 | 10:10 PM
DeathCougar's Avatar
The dealership sells a head rebuild kit that is very reasonably priced. Or use EngineBuilder. I have personally never used that company (all my stuff is OEM) but I have heard good things.
Old Jan 15, 2007 | 04:12 AM
AH64ID's Avatar
I just ordered a HG set and timing chain set (w/ steel guide) from engnbldr.com 102 to the door, and its all inclusive....
22RE's do not require new headbolts...
Old Jan 15, 2007 | 04:30 AM
Yoda's Avatar
Search is your friend here.
https://www.yotatech.com/forums/show...ht=head+gasket
I had done several gaskets on the kids truck. Finally went with OEM. Has pics of gaskets.
The difference was like an armored car next to a yugo
Old Jan 15, 2007 | 09:33 AM
yotaknows's Avatar
Thanks everybody...what are the chances of other damage to the engine as a result of the blown HG? I did not find but a dime size spot of chocolate milk oil under the oil cap after I shut her down, and she was running excellent.
Old Jan 15, 2007 | 09:41 AM
spudrunner's Avatar
Sounds like you caught the problem right away. I would expect minimal to no damage done to the bottom end. Get a good headgasket as mentioned above and if you've got the extra cash I'd go for new head bolts also.
Old Jan 15, 2007 | 09:43 AM
Elton's Avatar
www.engnbldr.com
Old Jan 15, 2007 | 09:45 AM
dcg9381's Avatar
Depends on how long your ran it and if it got enough water in the pan to get sucked up in the pump.
yotaknows's Avatar
Thanks again for the input..
kgcwb44
Jan 29, 2023 10:02 AM
wwjr
Sep 7, 2015 09:27 AM
o2raybid
Sep 4, 2015 12:45 PM
Gargoyle_Runner
Aug 28, 2015 01:36 AM
themightykhoner
Aug 11, 2015 07:37 PM
