- surging idle only in 2wd/mystery vacuum leak? 22RE
- Questions for you Toyota guru's
- 1990 4runner 4wd auto trans, no-start-no-click?
- Air intake: Extra boxes and hoses, is there a project page to reduce this mess?
- Rear window switch???
- Stock 94 Pickup Backing Plates Opinion
- 1st Gen 4Runner Payload
- No start HELP!
- Thermostat question
- 95 4Runner 22RE random hesitation until 3500ish
- 3.0vze no spark
- Oil leak help
- Idler arm problem - nut spins freely way before proper torque was reached
- Initial Timing after head gasket replacement
- 4Runner, Pickup, Pop Up Sunroof What year fits what?
- Talk me out of Air Lockers
- Headers and exhaust setups....94 4 runner 3.0 manual...what are u guys running?
- possible clutch issue
- 1987 4runner sr5 center console
- The Joy of a Japanese Screwdriver
- 95 3vze rebuilt alternator, not charging again
- Intake boot Fix
- Exhaust flange hitting frame
- 88 3.0 vapor lock
- Fuel injector problems
- 87 22re 4x4 engine rebuild
- Should there be a small hole at bottom of air-box ?
- Clanking from the rear end. 88 4x4 22re
- 12V Ignition Switched Source for 1992 Ext. Cab Pickup 4x4 3vze
- Has anyone re-routed their oil / trans dipstick?
- Neglected 92' 4R 3vze
- 91 4runner manual transmission out of gear but stuck
- Cam pin broke
- Help With Finding Black Steelies!
- Adding ATF to manual transmission?
- Speedometer quit
- 1992 Truck 22re Blown Head Gasket
- Oil pickup tube gasket
- 1993/1994 3.0 4runner 5spd transmission
- Air injection tube
- Harder starting after alternator replacement
- Leaking Coolant from freeze plug heater 3vze
- AXLE SHAFT interchangeability (1st gen Tacoma - 86-95 Pickup/4Runner)
- Coolant tube
- 22re exhaust manifold stud upgrade
- Overdrive Flashing continuously
- ARB Air lockers
- Mystery Ping pre-Detonation Sound on Acceleration
- suggestions about how to fix idle/ throttle bogging
- Transmission Cooler Leak
- Ps idler pulley bolt
- Bit the bullet...
- Coolant leak
- 22RE: Re-torque head bolts cold or hot?
- Gear ratio dilemma
- 1995 4runner - with 4" lift. Rear shocks help please
- Uunexplained Coolant Loss 1991 22RE 4x4 Pickup
- How does my 22RE exhaust sound?
- fixing rear door on leer shell
- No interior light lights except charge light
- 4runner heater blower motor assembly 1987
- Dash brake light stuck on shuts off when I push in clutch
- 22re + turbo
- Oboy, My 1st 4Runner..............Ever!
- Sae 90 gear oil?
- Power steering issue
- Rate my pistons 1-10? Pics inside
- Interior dome light bulb
- Rear axle not centered b/w passenger and driver side
- Wheel mounting flange outer tabs (REAR AXLE SHAFT)
- Transmission rebuild cost?
- No Power
- Shift on the fly after converting to manual hubs
- 1990 pickup 3.0 v6 losing throttle
- Obd port???
- Truck maintenance
- RIP '89 4Runner - Tubbs Fire Oct 9th 2017
- What Are Symptoms of Failing Ign Module 92 22RE
- Brass steering knuckle bushing IFS
- 3VZE Engine Overhaul, Ok To Use Stock Manifolds??
- Help with new 88 P/U
- High output alternator
- Replacing 3.0 valve cover gaskets. What else?
- 22re Dashpot adjustment question
- Alternator exciter charge?
- timing adjustment
- Question on REAR AXLE SHAFT NICK.
- can miss sized egr gasket cause issues?
- 95 4runner 4" lift, question about rear shackles
- Oil leak - need some direction
- Help! 22re no start after head gasket r2
- 18 degrees ice storm
- Too lean or too rich?
- 1990 Toyota 4Runner 4d 4wd Upper Plenum Removal
- 87 4Runner Heater Control Valve Bad?
- Best way to get a cam gear bolt torqued
- Knock sensor wire help
- Engine suddenly rough with choppy feel
- '86 Toyota Pickup Stall once put in gear
- 1995 4runner 3.0 Proportioning valve (HELL)
- T4R first gen - Dashboard LED lights
- 1987 Toyota p/u 4x4 22r problem
- Speedometer and Odometer and (maybe) Fuel Gauge Stopped Working
- engine will not continue to run after HG and fuel injector gaskets replaced
- 1990 4runner knock sensor code 5/2
- 1988 3.4 turbo build.
- charge and brake light on, changed alt brush, lights still on
- New motor NO power
- 95 4runner 3.0L wont start
- 1986 22re Manual trans fuel issues?
- U shape bypass coolant hose 22re
- Sound of Loose Chain on 22re
- Things that make you go...hmmmm
- 4runner 84-89 rear seat belt interchange with 90-95?
- 86 4Runner - Finding stock spare solution
- Continuous check engine light blink after replacing AFM & AFM pigtail/harness
- Rotor or bad Caliper
- O2 wiring harness
- Bad AFM ?
- Which springs to go with?
- Timing question for folks with a stock 22RE running high octane & close to sea level
- Sharing Toyota FSM?
- Diff Gearing Question
- Compression numbers?
- 1989 Toyota 4Runner
- 65 mph top speed... it sucks!
- 1987 4runner shift lever assembly
- 1990 4runner rear heater core
- Quick Question: 22RE Valve Spring Orientation?
- What Will New Suspension Do?
- Muffler/Exhaust options close to stock for 3.0 v6 95 4Runner
- SAS build with FJ80 front and BJ60 rear!!!!!
- coolant leak back of engine 3.0 4runner
- 95 4runner v6 3.0 pouring liquid coolant out the exhaust
- What seats you got?
- Axle identification help
- Anybody know what this plug is called, or where to get one??
- No Idle up on A/C or power steering
- Under hood lighting....
- what is this plug and where does it go
- Dragging Sensation Especially When in Low
- New Toyota Owner Has Suspension Questions
- 86 4Runner front seats replacement
- 22RE shop Austin
- Retro 80s halogen fog lights...i couldn't resist
- Coolant Leak w/ Unknown Source
- slow acceleration runs rough
- T4R first gen 1988 - Dashboard cover mat
- How do you price a 4runner when selling?
- 1993 toyota pickup issue
- T4R first gen - B-Pillar badges
- Vibrations After Third Member Swap
- Transfer case pinion seal
- Seat Belt Question
- 95 4 Runner, how many turns on air flow screw?
- 1990 pickup issues
- Fair price on 87 Pickup 4x4 22R
- 87 turbo 4runner speedometer
- 87 pickup starting problem
- New motor stalls out/No power help!
- 1986 4runner 22re hot start isuues with AFM?
- 2wd capacity diff
- Coolant Temp/Sensors
- 1998 4runner 3rd question
- Vibration?
- 87 4RUNNER won’t fire
- Vibration in 4 wheel drive
- T4R first gen - power steering reservoir decals
- '94 DX or std. cab
- Fj80 solid axle
- Whoops! Tried to pull CEL - shorted wrong pins!
- Restore ride to stock-like conditions?
- How much ATF does the torque converter hold?
- Hissing sound, Low idle / misfire - 22re
- Suggestions on what to replace during engine overhaul
- Will the rear sway bar from a 4runner fit?
- Is my 91 Toyota Transmission compatible with a 93 Toyota Transmission?
- 22re Failed Smog 3x Worse Gross Polluter After Rebuild. HELP!
- 1990 Toyota 4Runner 4d 4wd battery drain
- Trouble finding throttle cable for 88 pickup. Help!
- 1991 22re throttle problem.
- 22re coolant lin experts needed
- 1987 Toyota Windshield Wipers Stopped Working
- Call all 2nd gen 2-Door 4runner Owners! Need Help!!!
- pass seat under track slide cable
- Wacky mpg?
- Old Man Emu shocks too short
- 22re EGR Delete
- Smoked my oem alternator...
- Weird 2nd Gear Issue-Thoughts?
- Alignment issue
- Replacing Battery Cable
- R150f differences
- Ateering gear box exccesseive play after reseal
- 22RE oiling system
- Transmission fluid 2wd
- Inner hub gear
- Left automatic hub not reliable after rotor replacement
- Pictures needed 22RE
- Engine swap
- Rear window Clicking but wont operate
- Ok does any one know if and how to swap a automatic 22re transmission out for a 5 sp?
- 3VZE issues
- New toy. Need ideas.
- 1UZ vs 5VZ Power
- -20 Degs and Frozen 22RE...ughh
- Broken bolt & extractor suggestions
- Dually axle swap?
- 3vze oil sender replacement, need to remove this part
- No turn signals, nada zip
- clutch-whats the difference?
- 94 3.0 idle issue
- 87 22re won't start without gas/throttle
- Acceleration
- Doing donuts in my runner in the dirt now power steering pump vibrating
- ‘88 3vze no start help
- Post Dates
- Auto to Manual Swap
- Problems with manual windows
- 89 4runner tailgate
- 1987 toyota 22r smoking
- 1993 Toyota Running Lights Won't work
- Trans/ xfr case compatibility
- A340H transmission- first gear very sluggish
- Looking for suspention mods
- Hot wiring the rear window motor?
- 1990 Toyota Pickup Small Parking Brake Part Issue
- 5vzfe valve lifters - hydraulic vs shim
- Oil instantly turning black?
- 22re Rebuild OEM Part Help
- Rare tailgate latch?
- Top end noise
- Question about plastic timing chain guide pieces in oil pan.
- Super tech conventional motor oil walmart brand?
- Lug nut, 86 Toyota RV
- Broke my trans, need my man card revoked.
- 93 3.0 Clutch replaced
- 89 toyota pickup not staying running
- Could problem be anything but cracked head?
- "Something on the truck goes CLUNK CLUNK CLUNK"
- 1990 T4R 3.0 Running rich
- 1986 Toyota Pickup--Really need help with starting issue.....
- Tail light upgrades
- 3.0 swap to a 3.4 in 88 pickup
- 22re temperature sender thread size
- Help! 94 pick up transfer case seems stuck in neutral.
- power only to some fuses
- Help; which hitch will alllow a 31" spare to fit under the truck?
- 1993 3.0 Timing Issue ( help please)
