87 turbo 4runner speedometer
Old Feb 11, 2019 | 11:00 AM
87-4runner's Avatar
Anybody have any information on how to calibrate the digital speedometer... I'm off about 5 mile an hour
Old Feb 11, 2019 | 02:46 PM
beef tits's Avatar
You presumably have a geared sensor, rather than a cable right? Short of re-gearing the sensor at the tail-housing... I doubt it. This site has some stock tiny gears for sale...
https://khkgears2.net/catalog5/
I would give Marlin Crawler or LC Engineering a call, those guys have seen it all. They may know of a way. I'm sure by now someone has cracked open an ECM on these trucks.
Old Feb 11, 2019 | 03:18 PM
Paul22RE's Avatar
5 Year Member
Some here have used this device to re-calibrate their electric (non-cable) speedometers when changing tire size, no idea if it would work with a digital speedo?
https://www.summitracing.com/parts/dak-sgi-5e/overview/
Old Feb 11, 2019 | 03:21 PM
87-4runner's Avatar
Thanks I'll call MC and LCE
Old Feb 12, 2019 | 02:45 PM
Co_94_PU's Avatar
It might be possible to alter the digital dash, but the odometer is still going to be off since it uses a speedometer cable from transmission to dash.
​​​​You have to switch the gear on the cable at a minimum.
Speedometer isn't off five miles per hour, it's off X% unless it says five sitting still. A bit of a peeve of mine but I digress..
You are allowed somewhere between five and ten percent in the DOT regulations iirc.
Old Feb 12, 2019 | 03:06 PM
87-4runner's Avatar
thanks I'll check the cable and see of its like other geared ends that can be changed to less or more teeth...
Old Feb 12, 2019 | 03:52 PM
scope103's Avatar
WHY is it off? Do you have over(under)-sized tires?
The gears driving the speedometer don't just wear down. Something is causing this.
Old Feb 12, 2019 | 04:44 PM
87-4runner's Avatar
yes 31" so not a huge tire but enough to make 50mph showing on the digital dash, is actually 55 mph by android speedometer app...
soarerjzz30
Jan 18, 2007 04:13 AM
SpecializedBrder
16
Oct 17, 2002 07:25 PM
