Just did head gasket now I got crank no start
Old Jan 14, 2019 | 11:40 AM
85solidrunner's Avatar
just recently did head gasket water. Pump and timing chain on my 86 runner 22re got it all in right tighten valves go to crank it and cranks but no start noticed my fuel pump relay keeps blowing wat could be problem
Old Jan 15, 2019 | 12:29 PM
old87yota's Avatar
Welcome!
The fuel pump relay keeps blowing?
Do you mean a fuse?
Can you show us exactly what keeps blowing?
The "fuel pump relays" on these trucks are called Circuit Opening Relays because of the safety design of the fuel pump circuit.
Old Jan 15, 2019 | 03:55 PM
It’s a gold relay behind driver side kick panel under the dash but it seems to keep blowing and the fuel pump stops working any ideas of what to do
Old Jan 17, 2019 | 04:23 AM
1989pickup's Avatar
Might be a dumb question but do you have your intake all the way on ? On my 93 i did the exact same job and was trying to start my truck without the intake hooked up to the throttle body. I won’t start like that due to the sensor in the intake telling the fuel pump to kick on. Also make sure your timed correctly and not 180 off
Old Mar 21, 2019 | 08:41 AM
Steve Schieferecke's Avatar
Old Mar 21, 2019 | 09:00 AM
1989pickup's Avatar
I mainly meant the airboot that runs along the radiator that goes from the throttle body to the actual air box where the air filter is. Make sure that’s on or else the fuel pump won’t kick on besides the little bit of fuel it shoots in the manifold for a cold start
Old Mar 21, 2019 | 01:40 PM
roughridn_sob's Avatar
If you figure it out let me know dealing with the same issue. Head gasket change now fuel pump will only work when direct wired to battery. Gunna do some electrical trouble shooting tonight
MattyB4x4
Aug 31, 2017 04:09 PM
hermyboy3000
Aug 19, 2012 12:19 AM
Roofmaster
Jul 13, 2012 03:54 AM
WYrider
Aug 15, 2010 12:29 AM
camo31_10.50
Apr 12, 2010 12:24 PM
