Did head gasket job, tried to start - backfire through carb. Thoughts?
Old Aug 30, 2017 | 04:40 PM
MattyB4x4's Avatar
I overheated my 22r, forcing me to do a head gasket. Timing chain is a year or two old, guides are good. It's a trail rig and has probably gottan less than 500 miles on it in the last few years.
I didn't pull the timing chain, but zip tied it all together, went over the whole thing with a fine tooth comb, turned on the propane and went to fire it up.
It cranked a few times, then BAM - backfired through the carb.
I had the motor at TDC with the distributor pointing at the the #1 wire, but didn't know where to set the timing, so I put the distributor halfway between retard and advance. Is this a simple timing issue, or something worse?
Is it possible that my chain shipped a tooth somehow when I did the head gasket?
This is my first time really ever tearing into a motor, so if anyone has any tips, just pretend you're talking to a 5 year old.
Thanks!
Forgot to mention: I rebuilt the rocker arm assembly and relashed those. Is it possible that a rocker arm isn't lashed properly - thus a valve not opening as it should? I lashed them at .008 and .012 per FSM.
Old Aug 30, 2017 | 04:50 PM
MattyB4x4's Avatar
Well - I turned the distributor all the way clockwise and it backfired out the exhaust.
Sounds like I don't have enough timing? Move the distributor a tooth?
Old Aug 30, 2017 | 06:46 PM
L5wolvesf's Avatar
The usual suspects when this happens are: (in no particular order) timing, plug wires in wrong order, maybe one other thing I'm not recalling. Check your manual for setting the initial timing. Once you've double checked they are correct - check again. The chain could be off a tooth - how tight was the zip tie when you did that?I don't have a manual in front of me but your valve clearance numbers look off. - someone else here should confirm.
Old Aug 31, 2017 | 04:42 AM
MattyB4x4's Avatar
Ok...I'll check it again tonight.
Yes - valve numbers are off in original post...I typed them up wrong. It's .008 and .012 is what I set them at.
It is a propane motor and I set the initial timing at 0* per the FSM as well. I've seen that intial can be as high as 15-18* on a propane motor. I think that might be my issue...
I'll see what I can find on setting up initial timing and try it again. Thanks
Old Aug 31, 2017 | 08:07 AM
Melrose 4r's Avatar
5 Year Member
Engines run like crap at 0 degrees initial. If the timing recommendation is 5, 10 or whatever advanced, set that at the balancer first, then stick the disti in, rotor pointing directly to #1 on the cap and you will be good to go.
To ensure you are on the correct stroke, as you turn the crank watch the #1 intake valve open, then close, then bring the balancer timing mark up.
Old Aug 31, 2017 | 08:18 AM
MattyB4x4's Avatar
Ok, that's the plan for now. I've been googling like a maniac.
I think I'm just a tooth or so off on the distributor.
Thanks for the reply, Melrose - I appreciate it.
Old Aug 31, 2017 | 09:30 AM
MattyB4x4's Avatar
I currently have the Manifold Vacuum...or Idle Advance hooked up to the propane carb. Would that be causing an issue? I have the normal advance capped off and have never used it.
Old Aug 31, 2017 | 04:09 PM
MattyB4x4's Avatar
Well, just to follow-up.
I got the motor back to TDC, bumped the timing to 12* and it's running. I advanced it as far as I could, but I still need a few more degrees. Going to have to bump timing one more time.
Thanks all for the help!
