what is this plug and where does it go
Old Feb 15, 2019 | 10:40 AM
roughridn_sob's Avatar
Found this plug dangling while I was swapping out my transmission the other day. 1987 4runner SR5 , runs fine but Im sure that its supposed to be plugged in somewhere. Its hanging under the intake on the passenger side. I looked around but couldn't find any other open plugs.
Old Feb 15, 2019 | 05:31 PM
superex87's Avatar
My guess is cold start fuel injector. Will only affect starting in colder weather although I would plug it back in.
Old Feb 15, 2019 | 05:55 PM
Can you take a picture of where it goes? Truck has fired right up when the temp was in the teens
Old Feb 16, 2019 | 04:27 AM
wallytoo's Avatar
that is not the factory connector for the csi. i suspect that it is the connector for the FpU vsv located on top of the valve cover to the rear.
Old Feb 16, 2019 | 04:34 AM
87-4runner's Avatar
that's the coolest distributor boot...oem?
Old Feb 16, 2019 | 04:52 AM
wallytoo's Avatar
yes, as far as i know. both of my '87s have it.
Old Feb 16, 2019 | 08:56 AM
jazz1's Avatar
5 Year Member
I have a couple of those boots, one was in backseat storage in my '91 and another was on my '92 parts truck. I think often they get removed and lost or tossed.
Old Feb 17, 2019 | 06:36 AM
maco35's Avatar
I think is for the idle air control valve, it is just below the intake manifold.
https://www.yotatech.com/forums/f116...k-like-143319/
Old Feb 17, 2019 | 06:39 AM
maco35's Avatar
The one on post #12 is the one you're looking for in your '87.
Old Feb 17, 2019 | 06:52 AM
maco35's Avatar
http://board.marlincrawler.com/index.php?topic=36294.0
Old Feb 17, 2019 | 10:31 AM
se7enine's Avatar
If you find it doesn't go here to the IACV then it's an unused connector for an auto trans or something else. I can't remember what it was for. I've had two other 4Runners that had the same unused light blue connector dangling.
jentzschman
Aug 20, 2008 01:38 PM
Guardian_Saint
Dec 14, 2006 11:53 AM
JamesD
Jul 19, 2006 09:10 AM
