fixing rear door on leer shell
Old Mar 6, 2019 | 08:46 PM
jdfnnl's Avatar
Late last year I was posting about a leak at the back of my truck's shell in this thread.
Since then I discerned by a water test that the seal was failing not between the door and its frame but between the frame and the actual shell, as seen by the gap in this picture:
As opposed to using silicone here, I would like to remove the door frame and restore some kind of water tight seal. This video gives a good overview of removing and replacing the door frame:
However, it does not cover what kind of gasket is necessary between the frame and shell to form a reliable seal. I stopped by a local truck customs spot and they quoted me a little more than $100 with a new seal and rivets. When I asked what material would go between, they showed me something like this:
It looked like your standard open-cell low-density adhesive foam and thought I would check here and ask if this seems right or if there may be something more long lasting. I am thinking this type of material may be chosen over a closed-cell foam because it can be compressed very thin, and when the frame is cinched in place it will end up looking tight and clean.
Old Mar 7, 2019 | 04:14 AM
87-4runner's Avatar
I would revisit the silicone idea...
if you use masking tape you can create nice neat straight clean lines and you won't have to worry about leaks....
jdfnnl
Dec 25, 2018 03:52 PM
bruciep07
Jun 18, 2006 08:55 PM
JBTaco
May 7, 2006 02:17 PM
sc0tty
Dec 3, 2004 05:48 PM
boltman
Dec 3, 2003 01:38 PM
