Coolant tube
Old Mar 11, 2019 | 04:26 AM
Jf28142011's Avatar
Coolant tube
So I'm still putting motor together and need some clarification on something. There is a coolant tube on the 22re that runs under the intake manifold and bolts to the bottom of the intake. And wraps around the back of the motor. Cant seem to find the gasket for it. I've seen it uses a rubber o ring possibly. I do have an oring in the gasket kit but it seems too big. Does anyone know for sure what to use here.
Old Mar 11, 2019 | 04:33 AM
ev13wt's Avatar
5 Year Member
An o-ring. Of the correct size. :p
22reperformance.com should have it.
Old Mar 11, 2019 | 04:39 AM
Paul22RE's Avatar
5 Year Member
Part # for o-ring is 96711-24017
2 small bolts are 90080-11227
Old Mar 11, 2019 | 07:53 AM
Jf28142011's Avatar
ok. So no gasket. Just the oring then. That's the big part I wanted to know. Thank you.
Old Mar 16, 2019 | 05:48 AM
SomedayJ's Avatar
I had the same problem:
https://www.yotatech.com/forums/f116...e-trip-306382/
TIMBERWOLF61
Sep 29, 2009 12:22 PM
fire5
Nov 29, 2006 04:33 PM
txtoy
Jun 26, 2005 05:53 AM
wimpywade94
Jul 19, 2003 10:50 AM
