Coolant tube
So I'm still putting motor together and need some clarification on something. There is a coolant tube on the 22re that runs under the intake manifold and bolts to the bottom of the intake. And wraps around the back of the motor. Cant seem to find the gasket for it. I've seen it uses a rubber o ring possibly. I do have an oring in the gasket kit but it seems too big. Does anyone know for sure what to use here.
An o-ring. Of the correct size. :p
22reperformance.com should have it. |
Part # for o-ring is 96711-24017
2 small bolts are 90080-11227 |
ok. So no gasket. Just the oring then. That's the big part I wanted to know. Thank you.
I had the same problem:
https://www.yotatech.com/forums/f116...e-trip-306382/ |
