coolant tube gasket question
I'm in the process of putting my 22re back together and I'm not sure about a gasket to use. The metal coolant tube that runs behind the head, bends 90 degrees forward to travel to approx. half way along side the head and connects underneath the intake manifold to the manifold where there is a coolant sensor on top (I hope I'm explaining this well). I can't seem to find in my gasket kit anything to fit it. The only thing close is a brass or copper ring but I don't know if that's the one. Does anyone have any ideas or a picture of what to use?
As seen in this photo - behind the fuel line, correct?
http://lakebox.dnsalias.com/photos/1...d/DSC05525.JPG
Yes, you're correct. It is recessed. There's a bunch of gaskets in the kit that I have no clue what the're for. "O" rings as well. The one that came out of the connection is rubber, circular, but with 90 degree edges to fit snuggly into that recess.
Maybe the replacement is your typical "O" ring. I'll double check my kit.
the1998sr5
15
Jul 14, 2020 08:35 PM
DrZero
18
Jul 24, 2015 11:31 PM
