1990 pickup 3.0 v6 losing throttle
Old Mar 2, 2019 | 04:20 PM
bowhntr_ryser's Avatar
I’ve got a 1990 pickup 5 speed with 271k on it and recently it started losing throttle response when I get to about 55mph. As soon as it slows down to about 50 mph the throttle response picks right back up like nothing happened. If I put the clutch in when it has its hissy fit it will die. In the past it has thrown codes 24 and 41. It also has picked up a high idle. Everything I have read says that’s typically a vacuum line but I have checked all the ones that I can find and everything seems to be good. No cracked lines and seem to fit snug. Tonight I pulled the throttle body off and cleaned it. I have replaced the throttle position sensor (adjusted it to specs), the mass air flow sensor, has a new fuel pump and filter also. I have also ran all the wiring for the TPS circuit out all the way to the ECM. And they ohmed out. I’m just running out of ideas on what could be causing the throttle loss and what to check. Any help would be appreciated!
Old Mar 3, 2019 | 05:51 PM
amamike91's Avatar
Seems I read on here about engine throttle cutout at high speeds ( around 90 ish mph). Turns off the fuel pump until speed reduces. If this is correct then you might have something still out of whack. If I remember or find that post I will post it.
Old Mar 4, 2019 | 05:23 AM
That would make sense if it’s cutting the fuel off why it dies when I put the clutch in. I wonder if there is something that piggy backs off the throttle cable that goes to the ecm that could be throwing it out of wack.
oldmansimek
Feb 4, 2015 03:56 AM
youseemyevil
Apr 6, 2014 06:03 PM
PNW Yotanation
Oct 17, 2013 08:14 PM
Roofmaster
Jul 13, 2012 03:54 AM
toyotap
Feb 23, 2012 12:09 AM
