Go Back  YotaTech Forums > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Reload this Page >
Help! 94 pick up transfer case seems stuck in neutral.
Old 01-19-2019, 01:45 PM
5 speed 2.4 ltr. 94 pick up. W56 (top shift)
Transfer case seems to be stuck in neutral
. Despite manually moving shift forks from high/low & 2wd/4wd.
Issue happened after shifting from 4hi into 4low (stopped) transmission is a w56e.
Shifter removed for visual. Manually moving forks has no effect. With the shifter cover off I can see the center shaft turning. Once in a great while it goes into 4 high.
Spoolingturbo6 is offline
Old 01-19-2019, 02:55 PM
RJR
The only shift rail I saw you move in that video is the 2wd/4wd rail (the one on the right.) The left rail is the H-N-L rail. High is forward, neutral is centered, low is back. (Everything is exactly opposite of how the shift lever knob moves). It's hard to tell if your left rail is fully forward or fully back. For sure it's not centered, which it should be if the tcase is in neutral.
Also, unless your tcase has been modified for twin stick operation, the two rails should be interlocked, such that the right rail can only move when the left rail is fully forward, and the left rail can only move when the right rail is fully forward. So, if you are trying to move the left rail to get it out of neutral, first push the right rail fully forward.
Edit: Changed because I had forward/rearward interchanged.
RJR is online now
Old 01-19-2019, 03:12 PM
Fossilized
Staff
dropzone's Avatar
RJR is spot on
dropzone is offline
Old 01-28-2019, 07:34 AM
Correct. Both rails do move. I just couldn't get it to move in that video. It's now stuck in what seems 4low/2low something is up with the left rail.
jleathers
02-02-2016 06:28 AM
allenw
12-09-2013 07:58 PM
4wheelingyota
08-30-2010 04:45 AM
cw733
04-11-2010 10:33 PM
rv8er
03-08-2009 09:57 AM
Quick Reply: Help! 94 pick up transfer case seems stuck in neutral.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
