4runner heater blower motor assembly 1987
Old Mar 6, 2019 | 07:37 AM
Scott Mcgill's Avatar
1987 4runner DLX 22RE AT.. new motor, nice shape
have dead heater blower motor system in Vermont!
mechanic, not a toyota guy more of a Ford man, tried repair no good
no power to blower motor, fuses good,
new motor replaced two year ago, spins and accepts power etc.
replaced resistor unit new.
perhaps a short? Unit just stopped working 2 weeks ago.
any other components need changing?
I suggested doing a Rube Goldberg, wire direct to new single switch just on high speed to get some heat for remaining winter.
would that work?
maybe the fan speed switch is shot? any replacement for such?
any ideas?
thanks
Mcgill
Old Mar 6, 2019 | 07:50 AM
Naked Runner's Avatar
Did you check the relay and fuse behind the cigarette lighter? You can get to it pretty easy by removing the glove box if not.
Old Mar 6, 2019 | 08:05 AM
Paul22RE's Avatar
5 Year Member
This is for an 87:
Old Mar 6, 2019 | 08:09 AM
thanks for advice
Old Mar 6, 2019 | 10:22 AM
Co_94_PU's Avatar
A bad resistor or motor can out excess load on the switch. You can see in the schematic it's a typical toyota circuit with the switch on the ground side. In all positions the switch activates the relay and depending on the setting routes the current via the resistor.
Old Nov 15, 2019 | 07:49 AM
rattlewagon's Avatar
4crawler has some pretty good tips on the blower motor. Winters here, get that heat fixed!
https://www.4crawler.com/4x4/CheapTricks/Blower.shtml
cpljenkins01
Sep 24, 2018 06:19 AM
ugadawg95
Sep 28, 2012 05:16 AM
Team420
Oct 14, 2008 03:30 PM
kiteman
Feb 21, 2007 02:20 PM
Giraffe
Mar 6, 2006 01:07 AM
