87 4Runner Heater Control Valve Bad?
Old Feb 25, 2019 | 06:14 PM
Jessica Macneill's Avatar
Hey, we recently replaced most of the hoses on our 87 4Runner except for the one to the heater core. Drove 4 miles today and it was swollen like a grapefruit once we stopped. Could it just be a bad hose or the heater control valve? It doesn't look like it's opening but the heat works. Thanks!
Old Feb 26, 2019 | 07:56 AM
Melrose 4r's Avatar
5 Year Member
I'd think that when the valve is fully closed, no heat called for, the hose should be just fine, so it sounds like you have a weak hose. change it before it blows and leaves you stranded.
Old Feb 26, 2019 | 08:23 AM
old87yota's Avatar
I think the heater control valve is just fine. Even if the heater control valve is bad, it would not cause a hose to balloon up.
You have a bad hose and as Melrose 4R said, you will want to replace it before it completely fails.
It is also possible that there is too much pressure in the cooling system too and the weakest hose is what expanded.
snyderiii
Apr 22, 2013 12:27 PM
kcrunner
Feb 3, 2008 04:28 PM
LowHiLux
Jan 22, 2008 08:56 PM
InternetRoadkill
Feb 6, 2006 06:11 PM
Horseshoeing
Jul 27, 2004 02:40 AM
