Top end noise
Old Jan 23, 2019 | 11:57 AM
Jooosshua's Avatar
Smile Top end noise
I have a 1994 Toyota Pickup with a 22re that has just been completely rebuilt and I have had the rocker arms ground and refinished and also put a newcamshaft in and I am still haveing a tapping sound. I’ve had people tell me just to drive it that it’ll be okay just looking for other opinions. Thanks for any advice!
Old Jan 23, 2019 | 12:01 PM
Jooosshua's Avatar
Video of the truck
This is the noise
Old Jan 23, 2019 | 01:16 PM
NYHumpinUtah's Avatar
Welcome
How long after the rebuild? Have you adjusted the valves since the rebuild?
How does it run?
Old Jan 23, 2019 | 01:20 PM
87-4runner's Avatar
What clearance and how did you set the valves cold or hot? New timing chain, gear, and guides?
Old Jan 23, 2019 | 01:39 PM
Robert m's Avatar
How tight are the valve cover nuts?
Old Jan 23, 2019 | 03:10 PM
Jooosshua's Avatar
I just put the cam and rocker arms back in yesterday and adjusted them cold to .007 and .011 all the nuts were tight and looked fine
Old Jan 23, 2019 | 03:12 PM
Jooosshua's Avatar
I loosened the valve cover nuts earlier to see if it would change but it had no effect on the noise, everything in the motor is new it was just rebuilt last July with new head cam and rocker arm assembly. But what I thought was weird is the motor in it before this one made the same noise but that was a completely different motor
Jooosshua's Avatar
Truck runs absolutely perfect too. No problems with how it runs
Old Jan 23, 2019 | 03:57 PM
ev13wt's Avatar
5 Year Member
Originally Posted by Jooosshua
... But what I thought was weird is the motor in it before this one made the same noise but that was a completely different motor
I know that feeling.
On some days it will run perfect I promisr, but on most it ˟˟˟˟s with you.
Tick tick tick...
Old Jan 23, 2019 | 04:17 PM
snippits's Avatar
It's normal. Mine sounds exactly like that with new cam, and valves adjusted cold 7/11. Valves adjusted to 8/12 cold when I first got it back together are just a tad louder than the 7/11 I am running now. Not going any tighter.
Only cleaned the old rocker assembly. Maybe a new rocker assembly might quieten it down some. Mine runs just fine as it is. Tappy is Happy.
Old Jan 23, 2019 | 04:22 PM
Paul22RE's Avatar
5 Year Member
Originally Posted by snippits
Tappy is Happy.
Agreed.
Old Jan 24, 2019 | 01:32 AM
ev13wt's Avatar
5 Year Member
Sometimes it's actrually silent. This is OEM with 3K miles or so:
Today, it's tappin away.
Old Jan 24, 2019 | 03:50 AM
Melrose 4r's Avatar
5 Year Member
Im gonna say just try your valve adjustment once again hot at 7/11(not in the parking lot, though!)
Its most likely the exhaust valves. Being .001” off on .011” is going to sound worse than .001” off on .007”.
Bcurtis90
Oct 3, 2013 10:47 PM
87 4x4
Jan 10, 2011 08:49 PM
JollyGreen
Jul 4, 2010 10:28 AM
JohnStra
Jan 27, 2007 02:58 PM
Nyqill Junkie
May 2, 2006 05:06 PM
