Overdrive Flashing continuously
Old Mar 10, 2019 | 05:30 PM
Endlesstacos's Avatar
95 4runner 3.0L V6 SR5 Automatic
Check engine light came on recently and while checking the code by shorting the terminals etc, the Overdrive light blinked continuously with no pauses. The Overdrive light does not come on while driving normally, only seeing this while in the code check sequence. Anyone encountered this before and understand its meaning?
Old Mar 10, 2019 | 06:03 PM
scope103's Avatar
Welcome to YotaTech.
The light you were watching is the "overdrive-off" light. Which comes on, even while driving normally, when you turn overdrive off.
And when overdrive is on (so the lamp is not illuminated), it doubles as the transmission diagnostic code readout. Congratulations; your transmission passed diagnosis with no codes.
Here's some reading for you: http://web.archive.org/web/201408161...31diagnosi.pdf
Old Mar 10, 2019 | 06:21 PM
Cheers bud
Eagle564
Jan 8, 2015 07:09 PM
owbro
May 9, 2013 08:37 PM
881stGenRunner
Aug 8, 2009 09:16 AM
White4Runner
Jun 11, 2008 02:56 PM
BIGGAPPLE
Mar 7, 2003 06:53 AM
