- Loping cold idle below 50f
- How does this go back in??
- 91 4runner brake problems
- Power steering fluid cap
- replaced the head gasket and.....
- Lspv
- Need Advice in Purchasing parts for a full 22RE rebuild
- Need help with 22RE motor
- extreamly sloppy shifter
- egr hose blockage
- Serpentine Broke led to 30% loss of power, Timing off?
- Steering Gear Seals, August vs September
- Delay wiper issues 87' Runner
- 1986 4runner starter problem
- Custom Cab
- Quick question: sub-heated oxygen sensor
- throttle position sensor disconnected
- My 3vze heads warped all bad
- Idle issues on my 22R
- Drive Shaft issues
- SMOG Fail, high HC (PPM) and CO (%)
- Do i need a rear cv driveshaft??
- Cross country move with 90 pickup
- 3VZE fan bracket PULLYS!!!
- Mile Marker Hubs
- Warn Hub back to OE Aisin Manual Hub Conversion
- 88 4runner brake problem
- Brakes don't lock...Is that a problem?
- Urgent 3VZE tranny help
- Gotta Know if You Know
- few questions on my 94 4 runner 3.0
- Internal Leak HELP!
- Ignition cylinder removal 88 4runner
- 86 yota truck 4x4 exhaust manifold glowing and drinking gas baddd
- 1995 3.0L 4Runner still wants to overheat! Why didn't my pickup do this?!
- Shop says I need a new engine
- Throttle sticking, RPM all over
- 3.0 header question??
- 3.0 crossover question
- Steering wheel noise?
- Obd?..
- tps/auto tranny issues?
- Lifting advice?
- What should I make for my 4Runner?
- Red vs. Green Coolant? (3VZ)
- Rough Country or Trailmaster
- heater not working-1991 toyota truck
- Trail gear rear disc brake kits
- clutch hard to grab
- Suggestions Wanted: Jerry Can Mount for Pickup
- can a bad circuit open relay cause a 3.0 momentary miss
- ahh joy.....clutch leak and code 5
- Wheel seal issues
- Rear passenger window question
- 94 2wd cab to 87 4runner frame swap
- Wet Okole Pics
- Please help me with my tranny!
- My 1992 yota finally on the road
- Wont Start after head gasket replace
- loss of power, weird surge, 22re efi
- Popping in 4x4 Even When Stationary
- 92 4Runner leaking oil, looking for advice.
- anyone have a york compressor on there 3rzfr
- Can someone tell me where my diagnostic port is?
- Honest Opinion - Check Engine Light Code 52 (Knock Sensor)
- Need a step by step clutch bracket removal/install
- Cold Start Injector Test
- What Ac part darts do I need?
- Please help on bad idle and hard start??
- Losing clutch fluid, but where?
- Poor Gas Mileage
- 3.0 MPG Thread Beat to Death... What Can We Do???
- 89 yota
- Maiden voyage in the mud
- Good bye 4runner
- Fuel Filler Hose sizes
- Idea on extra trans cooler on my 92 4runner auto?
- What does the box above rear axle do?
- 87 22R: Oil fouled plugs and smoking on acceleration :(
- Regular cab vs Ext cab
- 86 4 runner brakes locking up
- Celebrating Labor Day toppless
- Low MPG, rebuilt heads
- Big Rig on-board air??
- Flat Springs
- Cannot get my DISTRIBUTOR to install
- Another fj80 coil swap question?
- 2nd gen 4Runner 92 Body Mount Questions
- Easiest way to install fron LockRight...
- Codes 2 and 11
- 3ZVE Oil Consumption
- Rebuilding 22re; doesn't rotate smoothly
- 3VZE - Is this normal? {Video}
- body rock
- HUM what muffler to buy
- fuel pump
- High Idle
- Engine Starts HOT After Stopping for Gas/Bathroom
- TPS Adjustment for 91 pickup, 200-800 ohm or .47 to 6.1k ohm?
- No Power to circuit opening relay
- Alternator fitting issue 1992 Toyota Pickup 4x4
- Center console help!!??
- Part number for 3vze "Water Temp. SW connector"
- 87 22r with 10k rebuild on longblock burning oil
- 22re Rattle help appreciated
- Coolant Leak Back of 3VZE
- 22re misses and bucks in 1/4 throttle
- 99 4Runner EGR Valve Temp Sensor
- Hazard/turn signals dead...
- ball joint lift and 4 inch lift
- Whats this switch do.
- 1988 4x4 toyota cannot get the timing right!
- new guy 93 4x4 Pickup w/ 22re and 5 speed knock sensor wiring issues
- Bilstein shocks
- Shake at highway speeds
- Thank you!
- Third member removal/replacement
- Need help truck sputtering
- What happened here?
- Seat swap for tall guys help
- Anyone replace stock muffler with a turbo ?
- Coolant temp gauge issue?
- 95 3.0 Misfire When Cold
- License placement with tube bumper
- Looking for Good Alternator Upgrade Info
- Aligning Wiper Park Position?
- Deciding on rebuild kits
- Junk yard leaf spring options???
- Ideas on junkyard leaf springs???
- Expensive mistake - radiator damage, etc.
- Sticky hubs
- Speedometer cable ticking
- Cant get Ball Joint out
- Bumper valance replacement?
- 89 Toyota pickup power prob
- Rear Window Wiper Motor Adjustment???
- Can You Help Me Change this Hose???
- head gasket oil leak...bad?
- A/c pre cooler question
- WARNING!!! 3vze Headers and Melted fuel line
- How much lift with Rancho torsion bars?
- 2001 4runner black wheels
- 89 1 ton Motorhome: shock recommendations?
- 22re runs fine, then power loss
- need quick answers on 22re to 3.0 swap in 93 pickup
- Where to find replacement rear quarter panels
- List of known usable junkyard springs for zuk mod?
- Size of u joints in Camden joint
- blew motor today, opinions on options
- Fuel Pressure Regulator VSV
- need some advice: block replacement with shackle and AAL options
- Need some help...
- 22R 4Runner Igniter Assy
- 2 row or 3 row radiator???
- Catalytic converter stolen... California
- Oil Pump replacement question, and a few others
- 1987 22RE- reman AFM fails same to original?
- New Guy, code 25 help.
- Exhaust manafold gasket replacement
- Shock and Coil Input
- 87 4Runner
- frustrating/puzzling powersteering leak
- rear diff question
- '86 22re full pump not staying on
- 3.0 rebuild
- worn motor mount signs??
- rear wheel grinding
- Left-over Part. Any Ideas?
- Blowing Fuses when in reverse????
- 92 toyota pickup won't start
- Tranny pieces
- regular vs extended cab lift kits?
- {WTB} 4:88 rear 3rd
- 84-88 SR5 Center Console Lid Question
- how to disable a fuel pump.
- Speedo cable still wont work
- Best Shop Manual '88 4w Pickup
- 1989 4runner parts ordering problem
- Body compatabilities
- Non-Toyota Coolant opinions...Zerex? Pentofrost? Peak Global?
- 89 toyota 5 speed trannny problems?
- W56 Top Shift Rebuild With Marlins Kit - Pics Along the Way
- Difficult to put in to first gear
- time to replace transmission?
- Need some advice on EFI relay
- help 1992 22re engine bay fuse diagram
- OIL PAN: RTV or Gasket?
- weber 32/36 setup/diagrams
- 4Runner Overheating/Super Low Idle
- lets talk 22r timing
- Anyone use adjustable slave cyl rod??
- Mercedes Turbo Diesel Swap?
- Side view mirror glass replacement
- 1993 4runner rebuild - plate between engine and trans
- 1991 4runner crankshaft replacement
- Uneven Idle
- Bought an '86 - How'd I do?
- 88 Toyota pickup when trying to start the starter relay clicks
- 94 pickup starting problem
- Knock, Ping, Tick. What is it
- Distributor compatibility, 2nd gen 4runner
- rough idle issue
- headlight brackets
- Interior and dome lights not working
- factory skid plate?
- Is my fuel pump shot?
- 89 PU bouncing at highway speeds.
- Rebuilt 22RE issue, human error
- air bubbles in expansion tank.
- 22re won't fire, gm module swap still won't run
- cant set my ignition timing..plz help
- "Top Line" Head Gasket ????
- My First time. 91 yota 22re.
- O2 Sensor
- smoke on decel, oil in intake 22re 4runner
- Daily Driver Build for 11k?
- Where to get COAX for code 52?
- The best springs
- 1st yota, braking issues
- 89 4runner just won't give up.
- A/C not blowing air
- a lil help please? running issues....
- Alignment issue
- Coolant leaks, missed the obvious...
- 90 Pickup died, replaced dist, now barely runs!!
- What's my gear ratio?
- 3.0L injectors
- 87 turbo diesel questions
- what do you guys think project runner
- exhaust dilemma
- I ate my steering alive
- Engine Rebuild First Started Now No Start
- 3RZ Swap with IFS - few questions...
- Extended rear brake hose 95 4runner
- Got front diff. out, pan loose, cant get pan to come free. advice?
- 1991 4WD Pickup - Can You Tow On All Four Wheels?
- idot lights on in dash
- Point me in the right direction to a diagram of the harness for the engine bay
- tundra brake swap on SAS
- Size of sticker on 1995 Pickup tailgate
- 1986 SR5 fuel supply problem
- need help explain parts??
- 3.0 Headgasket and Crossover Queston
- '86 22re wont run
- Need some quick Supra AFM Help
- '86 22re pulsation damper delete?
- 2.7
- 94 Toyota Pickup NO FUEL NO FIRE
- Port / sensor on top of V6 diff? Thread size/type?
