need help explain parts??
Old Aug 18, 2012 | 02:31 PM
tyes's Avatar
I have a 86 T4R but installed a 87 22RE engine. I used my ECU, wiring harness. That 87 was an automatice. Everything plug up like a charm. I have a slight miss firing and suspect a vacuum issue. I have extra vacuum hoses that do not connect to anything. Car runs great with alittle trouble of starting, which is another issue. this image is for a 88 22RE, but these are the 2 items circle in red is my question.
What is the AS REED VAVLE? What does it do? I sure dont have one and therefore cant plug up my VSV? The other valve or sensor circle next to the VSV. WTF is it?? I am frustrated to the point where i can not find anything about this.. Please please do help. Unfortunately, these are the only diagrams i was able to find online or via my 88 22re FSM...
Old Aug 18, 2012 | 02:36 PM
myyota's Avatar
Im not sure about the vacuum lines for the reed valve, but if your truck never had the reed valve then just plug the vacuum lines. The VSV on the valve cover is for the fuel presure regulator..
Old Aug 18, 2012 | 02:37 PM
tyes's Avatar
Oh BTW, my VSV is dead too...Did a OHM test and nothing happen. I blew air into the valve and it was good though..
IF ANYONE HAS A VSV FOR SALE I WOULD LOVE TO TAKE IT OFF YOUR HANDS..
Old Aug 18, 2012 | 02:49 PM
tyes's Avatar
Thank you I will give that a try...
88sasturbotoy
Jan 30, 2026 01:57 PM
May 20, 2016 10:27 AM
Fundy Rider
Jul 16, 2015 01:35 AM
smiley52
Jul 11, 2015 05:16 AM
akaphilly
Jul 9, 2015 02:34 PM
