Oil Pump replacement question, and a few others
Old Aug 27, 2012 | 06:30 PM
01B3K's Avatar
Well, replacing the oil pump in my 88 22RE, as soon as the new rear springs are in, )but thats besides the point)
My question is, my brother is rebuilding his saturns engine, and he has to pack his oil pump with some sort of Vaseline type gel or something. Do i have to do the same thing, or do I just have to lube the pump with fresh oil before puting it in?
Also, anyone have an image of the adjustment/equalizer bar for the parking break? The one that connects the end of the front cable and the rear cables together.
Thanks in advance
Old Aug 27, 2012 | 07:50 PM
matstaley's Avatar
Make sure the pump is super clean and pre-lube it with motor oil. You can use white lithium grease but I don't believe its necessary.
GreenLion
Jun 7, 2021 10:49 AM
Ichneumon
Sep 27, 2015 04:21 PM
85run
Jul 8, 2015 11:20 PM
puddlepirate
Jun 30, 2015 05:08 PM
Mutinebullfrog
Jun 18, 2015 01:36 PM
