idot lights on in dash
Old Aug 19, 2012 | 04:32 AM
skinny's Avatar
Ok I washed under the hood of my 94 3.0
now I have a bunch of dash idot lights on
bat/brake/at fluid temp/ think more
I'm also not sure it is charging now even though the gauge says it is
need help is there a certian spot I should try and dry out
Old Aug 19, 2012 | 05:35 AM
Stu Pidasso's Avatar
I would try the fuse panel/ relay box under the hood on the passenger side.
Old Aug 19, 2012 | 06:15 AM
skinny's Avatar
Ok there is 2 a small one and a large
My small one has no lid
Old Aug 19, 2012 | 06:52 AM
That is probably a good indicator of your problem. The small one you are talking about does it have fuses, relays and crap like that in it? Or does it have a bunch of little ports in it that look like you plug things in to it?
Old Aug 19, 2012 | 06:59 AM
skinny's Avatar
there is the big one that has a bunch of fuses and relays it has a small test port off one end and on the side there is another little one has 2 relays and a fuse
I have looked under the lid of big one it apears dry
the small one on side missing the lid I pulled relays and fuse all look dry
never looked in test port
did the old pull pos off battery test for charge and dies right away
starting to think alt all of sudden
but need to make sure (really broke can't do extra parts)
Old Aug 19, 2012 | 07:11 AM
You can take your alternator to the local parts store and get it tested. A friend of mine one time took his off and used a drill with a socket to spin the pulley. He then used a muli-meter to varify output. One other thing that may help is this. There is some spray made by Ideal that you can get at Lowe's or Home Depot. I got mine at Lowe's. Anyway, it is electrical contact cleaner. This stuff has an agent in it that dries very very fast. You may be able to use it dry out the junction box under your hood. I would strongly caution you to make sure that all the cleaner is dry before applying electrical current to your system. So if it were me I would do this....
1. Disconnect Battery CABLES
2. Remove bolts that hold junction boxes to the body. I would look at the little clear tops that are on my slow burn fuses/fusible links and make sure no water is in them. I would take the other "small fuse box" (which I think is your test connection terminal) and turn it upside down gently.
3.Then spray with the contact cleaner. This stuff will clean up the connections and should displace the water.
4. I would take a fan or fans if you got them. Position them under the hood and or truck and turn them on so air can circulate.
Old Aug 19, 2012 | 07:14 AM
The fact that all the idiot lights are on makes me think that you are getting a short or shorts in the system.
Old Aug 19, 2012 | 07:21 AM
skinny's Avatar
so you think there is something in the relay boxes stopping it from charging
like I said the relay stuff loos pretty dry
what should I get voltage wise off the big post on alt if i put my meter on it
Old Aug 19, 2012 | 08:52 AM
skinny's Avatar
well I'm pretty sure it is the alternator i checked for voltage at the large positive post and only got the same as the battery voltage
how long do you think you can drive on a fully charged battery
Old Aug 19, 2012 | 08:57 AM
jslone's Avatar
I blew an alternator belt in the middle of the night in a huge rainstorm 35 miles from home. I left the lights off, didn't use windshield wipers and turned off everything else that would use electricity. I squinted to see the whole way and coasted into my driveway.
ashersullivan88yota
Jan 18, 2022 05:37 PM
mussy01
Dec 13, 2016 08:20 PM
AkitaDog
Sep 1, 2015 08:05 AM
ViperTT
Aug 14, 2015 05:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
