Alternator fitting issue 1992 Toyota Pickup 4x4
Old Sep 1, 2012 | 05:19 PM
quidprocrow's Avatar
I am currently in the process of changing out my alternator on my 92 pickup. I had difficulties removing the alternator from the location where the pivot bolt is located. I had to use a crowbar in order to pop it out...the obvious problem now is putting the new alternator where the old alternator was located....it seems to be such a tight fit i feel like it is going to be impossible to place it back in its original location. any ideas, suggestions or if others have had similar problems I would love to hear possible solutions. Thank you very much for your help.
Old Sep 1, 2012 | 05:26 PM
motocrossaddict223's Avatar
It will go back it, trust me. Its probably just because it hasnt been removed in ages. Once you do it a few times itll just literally fall out. Dont be afraid to manhandle it around, be careful with the crow bar around the timing belt cover, dont wanna crack it.
Old Sep 1, 2012 | 05:27 PM
Forgot to ask, what motor is it? That info is for a 3vze. If you have a 22re, i have never done it.
Old Sep 1, 2012 | 05:29 PM
Thanks for the response, it is a 22re.
Old Sep 1, 2012 | 05:34 PM
Hmmm, I can offer you my experience that I have on my 2rz....yes it's very difficult; at first but it will go back in..try talking dirty to it
Old Oct 18, 2013 | 05:13 PM
ro6ot's Avatar
follow- up advice?
Hi, I have a '93 4X4 P.U. w/ 22RE, I need to change the alternator also.
I have the durned thing free, now I just can't get it out!
in order to take it UP, the steering assembly (and it's own bracket) is in the way.
Should I drain the radiator so I can take off the lower hose,
-to drop the alt. DOWN & out-
is that the preferred method?
any advice appreciated!
Old Oct 18, 2013 | 05:27 PM
Toyota~Boy's Avatar
You shouldn't have to drain radiator but I remove mine through the bottom. Remove skid plate and pull it down outa there. Going back can be a little rough but you can do it.
Old Oct 18, 2013 | 06:24 PM
ro6ot's Avatar
thanks man, I'll have another go tomorrow.
This truck is lifted and has a lot of extra (hydraulic? pneumatic?) cross-brace-ey stuff down there (sorry, don't know the right words yet; just got it recently)
Old Oct 19, 2013 | 12:20 AM
wyoming9's Avatar
Red face
I find it is so much easier just to remove the lower hose.
To me it is saves a lot of frustration and time.
Not like your doing this all the time might be time for a new lower hose and new coolant any how.
Old Oct 19, 2013 | 08:25 AM
NickL's Avatar
Originally Posted by wyoming9
I find it is so much easier just to remove the lower hose. To me it is saves a lot of frustration and time. Not like your doing this all the time might be time for a new lower hose and new coolant any how.
This is the way the FSM recommends as well.
Weidle
Jan 21, 2019 05:39 AM
Aleeex_u
Jun 5, 2016 06:52 PM
taraf
Sep 24, 2015 08:33 PM
bprice0077
Jun 25, 2015 07:36 AM
paxanders
Jun 21, 2015 06:29 AM
