Cannot get my DISTRIBUTOR to install
Old Sep 2, 2012 | 08:31 PM
cous22's Avatar
Hey, so I'm just finishing up a head gasket job on my 1995 3.0 V6 4runner and I cannot get the distributor to sit. For some reason I cant for the life of me get the gears to line up and it just wont sit in there!
any help!!?
Old Sep 2, 2012 | 09:32 PM
Bassmastry101's Avatar
When you install the distributor it turns as it goes in..so in order for it to be set on TDC you need to turn it back a little so it can turn to number 1 while you slide it in.
Old Sep 2, 2012 | 10:19 PM
85gijunk4x4's Avatar
try roatating the engine just a tiny bit, maybe the gears are interfering, the to get them to line up you just need to move the engine over to where the gear tooth isnt, like a 16th of a turn or so. Or hold the dizzy in place as far as it'll go in, and turn the distributaor shaft as you rotate the engine
Old Sep 3, 2012 | 07:25 AM
cous22's Avatar
thanks
Thanks for the tips, ill give this a try. All the resources I find are for the 4 cylinder and that distributor is a straight shot where as the 6 is on top of the head at a bit of an angle.
Old Sep 3, 2012 | 07:27 AM
cous22's Avatar
and im guessing the rotor will spin counterclockwise?
Old Sep 5, 2012 | 05:34 AM
If I remember correct yes it would turn counterclockwise when it goes in. So turn the rotor right past the number one post so it will turn to line up.
Old Jan 6, 2013 | 02:51 PM
kawasakikid's Avatar
distributor wont go in
I just put new heads on my 1990 3.0 v6 4runner and am also having the same problem. How did you end up getting it in? I have about a quarter inch gap between the distributor and hole can't figure out what's hitting. Any help is appreciated
Old Jan 6, 2013 | 03:07 PM
b4wheeler's Avatar
There is an exact install procedure for the distributor..... There are two notches that line up on the distributor and then they in turn line up with a mark on the distributor housing on the head. Get all this done correctly and it will be set correctly to get the engine started and timing should be just about dead on.....
Old Jan 6, 2013 | 03:10 PM
Alright thank you. Is there anything on the cam that needs aligned or just on the distributor?
Old Jan 6, 2013 | 03:13 PM
b4wheeler's Avatar
Nope just the distributor.. The cams are aligned when the belt is installed.....
Old Jan 6, 2013 | 03:14 PM
Ok thanks again I'll give it a try tomorrow when I go my garage
Old Jan 10, 2013 | 12:30 PM
Ok so I tried it and still doesn't go in this is the gap I pulled the valve cover off to see if I could see anything but all I am seeing is the shaft doesn't look like its going all the way in the hole that's in the head?
Attached Thumbnails Cannot get my DISTRIBUTOR to install-2013-01-10_15-45-03_695.jpg   Cannot get my DISTRIBUTOR to install-2013-01-10_15-44-40_114.jpg
Old Jan 10, 2013 | 12:44 PM
Gamefreakgc's Avatar
This may help, or may just confuse.
My 91 3VZ-E pickup has TWO different distributors that were made that year. I had the wrong kind the first time, though it managed to fit the truck ran horrible. I'm not sure if that's the case for 95, but might be worth looking into.
Old Jan 10, 2013 | 12:49 PM
Thanks I just took the bearing cap off and can see thelat the distributor is bigger than the hole in the head so I'm not sure what I'll do
Old Jul 8, 2013 | 03:53 PM
jdreynolds2's Avatar
Has anyone had this problem with an 88 4Runner? Do you know if there are two different distributors made that year?
Old May 8, 2018 | 05:09 PM
Trevor101m's Avatar
I have the same problem exactly did u find a solution?
cars-guy
Aug 16, 2020 06:59 AM
raptor510
Feb 17, 2017 07:11 AM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
msane99
Jul 11, 2015 08:08 PM
