Need some quick Supra AFM Help
Old Aug 18, 2012 | 11:04 AM
CajunKenny's Avatar
Hi,
All I need is a link to that thread that listed all the Supra AFM Part#'s and what the pinouts are.
I have been searching for about 20 minutes now and thought that someone may have it.
Can someone help a brutha out!?
Old Aug 18, 2012 | 11:26 AM
angrybob's Avatar
Part# 22250-43110
This is for the '82 Supra. It is plug and play with a cone type filter and a little fitment in the spot where your current airbox is.
Use google.com for your search.
Old Aug 18, 2012 | 11:41 AM
CajunKenny's Avatar
I have that info, what I need is the pinout info that someone put together. They had listed all the pinouts with the corresponding AFM part numbers.
I ran across the thread about 6 Months ago.
Oh...and what's google?
Old Aug 18, 2012 | 01:30 PM
myyota's Avatar
The AFM from a mid 80`s cressida will also work and has the same part number as the supra AFM, 22250-43110. Im running this AFM on my 86 4Runner and its plug and play.
Old Aug 18, 2012 | 02:17 PM
CajunKenny's Avatar
Yep. I'm up on all that info.
I need that "write up" thread that has the pin-out information.
Old Aug 18, 2012 | 02:39 PM
myyota's Avatar
It would be a big help to us if we knew what year your truck is ???.
Old Aug 18, 2012 | 02:45 PM
MudHippy's Avatar
Not a "write-up" per se. But here it is...
https://www.yotatech.com/forums/f116...p-3vze-226865/
Word of caution: AFAIK there are no cross-references available to confirm the information found therein regarding the pinouts of the VAFMs not used on the 22R-E or 3VZ-E. The accuracy of the other VAFM pinouts listed as being used on other engines is therefore unproven. And the pinout listed for the 22R-(T)E is mislabeled. Though it appears to be mostly accurate in other respects. Of particular note the #5 pin being labeled ECM (+8v), should technically be labeled Vc (+12-14v or battery voltage). Though the actual voltage measured at Vc-E2 should range from 6-10 volts, according to the FSMs. I assume the voltage measured as such is being affected by the resistance in the Vc-E2 circuit. And presumably the voltage measured at Vc-E1 would then be equivalent to the battery voltage.
The 22R-E VAFM pinout from the 93 and/or 95 FSM is as follows:
1= Fc
2= E1
3= E2
4= VB
5= Vc
6= Vs
7= THA
Old Aug 18, 2012 | 04:03 PM
CajunKenny's Avatar
I've got an 87 4Runner.
That's not the thread I was looking for; but, does have good info. It may prove to even be helpful. Thanks!
By the way...I'm an Electronics Technician so you're talking my language!
Here's what I'm trying to do. I have an AFM off an 83 Supra and instead of switching out the electronics, I would like to just switch the wiring.
This phantom thread that I'm looking for (kicking self for not subscribing to it) had the information I need to do that.
Old Aug 18, 2012 | 06:18 PM
Robert m's Avatar
https://www.yotatech.com/forums/f116...ssidas-137629/
10 second google search
Old Aug 18, 2012 | 06:47 PM
MudHippy's Avatar
Originally Posted by Robert m
Dah...NO. Sorry. Try again. That thread has the same EXACT set of pinouts as the thread I posted the link to. Which you didn't even bother to look at right?
10 second google search? Why I oughta...what kind of fool do you take me for(us for...excuse me).
PS, JamesD, good job and all. But where's your proof of any/all of that(as in, where's the official documentation of those supposed pinouts)? And here's a hint...brush up on your knowledge of how a Toyota VAFM functions. NO 8 volt reference!!! I can see where you made that mistake(what's the middle number between 6 & 10?)...but trust me...THAT'S WRONG!!! Read here.
Old Aug 18, 2012 | 10:04 PM
Robert m's Avatar
well, i guess you caught me hippy, as i do tend to just skim right over most things you post...
OP goodluck!
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
zytra
Jan 24, 2019 03:16 PM
charlie_fong
Sep 27, 2015 10:06 PM
toyotasaurus
Sep 24, 2015 03:30 PM
