What does the box above rear axle do?
Old Sep 3, 2012 | 06:20 PM
ACZR's Avatar
Hello, I need information about the brake system on a 1991 Toyota pick up, the part I am wondering about is on the rear axle the the part that travels from the box, down to the axle. From what I can figure it is some type of adjustment that would aid in braking if a heavier load was being hauled? What I am looking to do is eliminate this and am just trying to find out what parts/knowledge is needed to do the job, if there has already been a decusion on this I do appologize but I was not sure what the correct terminololgy for this was so the search did not yeild anything helpful. Thank you all for your advice.
Old Sep 3, 2012 | 06:22 PM
ThatGuy1295's Avatar
https://www.yotatech.com/forums/f116...emoval-151303/
Here go.
It stands for Load Sensing Proportioning Valve.
Old Sep 3, 2012 | 06:23 PM
TNRabbit's Avatar
It's called the LSPV, or load sensing proportioning valve.
I don't suggest removing it unless you are going to install an adjustable valve.
Old Sep 3, 2012 | 06:27 PM
ACZR's Avatar
Thank you very much for the quick response and the link to the info.
Old Sep 4, 2012 | 04:21 PM
abecedarian's Avatar
LSP-BV (Load Sensing Proportioning Bypass Valve)
It also lets you have your rear brakes if the front's loose functionality.
88sasturbotoy
Jan 30, 2026 01:57 PM
jerusry
Oct 19, 2015 05:28 PM
gieselman
Oct 12, 2015 01:34 PM
deepmarsh
Aug 6, 2015 03:44 AM
toyoda8488
Jul 5, 2015 10:18 PM
