air bubbles in expansion tank.
Old 08-21-2012, 07:06 PM
whiteyoda93's Avatar
ok. I have a 93 22re. a few weeks ago my temp hand went about 3/4 across. never actually read hot. I shut it off and could hear the coolant boiling in the expansion tank beside the radiator. the next morning I drive it to town and temp hand never goes past 1/2. since then I have replaced the thermostat and radiator cap. haven't heard the boiling again but when I shut off the engine and look in the tank I see some air bubbles coming out of the overflow tube. truck only has about 14000 on rebuild. it's not using oil or coolant. no milkshake on the dipstick when I check oil. no steam out of the tail pipe. my question is. could I still have a blowed head gasket? since new thermostat the temp stays about 1/4-1/2. fan clutch is good also.
Old 08-21-2012, 08:00 PM
ksti's Avatar
If you want to make sure, pressure test cooling system (also cap) and do a block check for exhaust gases in cooling system.
Blamalam
03-12-2022 07:34 AM
the1998sr5
15
07-14-2020 08:35 PM
skoti89
09-11-2015 07:46 AM
Ohio4Runner
08-31-2015 05:45 AM
Logz808
07-26-2015 07:09 AM
Quick Reply: air bubbles in expansion tank.
